Hi here I have for sale my pride and joy Alfa 145 with a fiat coupe 20vt engine transplant.Only reason I'm selling is I'm in the process of buying my first house so need all the money I can get.
The car is very quick and a lot of time and money has gone into her.This was not just a transplant it was a complete shell strip down and rebuild with everything replaced.
Alfa Romeo 145 20v Turbo
1997
80 000
Mot: Feb 2015
Tax: 4months
Harlow Essex
£3600 neg
Gary 07758839639
Mods:
17" Compomotive Mo5 newly powder coated in anthracite grey
Toyo Px4 tyres basically new all around
Full FK Coilover Kit
Full rear Subframe polybush kit
Full rear subframe overhaul with new trailing arm bearings and painted
New handbrake cables
New Rear Brake compensator
New rear brake lines and flexi
Full Stainless Custom exhaust
Fully overhauled and painted rear calipers and disks with pads
Fully overhauled and painted front brembo calipers and disks with pads
Front polybushed ARB with uprated ARB
Fully overhauled front subframe and painted
New Brake lines in the front with flexi
New lower control arms
New engine mounts including upper torsion bar polybush conversion
Custom smoothed and painted front and rear bumpers with splitter in front
Uprated to 10bar front mounted oil cooler with custom made pipes
Front mounted and painted ontercooler
Side skirts all been carbon wrapped
Wheel arche kit carbon wrapped and fitted
Bonnet carbon wrapped
Carbon wrapped wind deflectors
Headlights stripped adjusters fixed and angel light conversion on side lights including full HID 8000 conversion on headlights
Carbon wrapped headlight eyebrows
Carbon wrapped boot spoiler
Fiat coupe front leather seats with momo leather rear seats
Alfa romeo headrest covers
Full centre console conversion fitted
Battery isolator switch fitted underneath centre console
Brand new battery and stainless steel racing tray fitted into boot with new terminals
Full 3" induction kit fitted
Boost point for jump start installed in engine bay
Completely rebuild 20vt engine with port and polished head
Lightened flywheel
Uprated walbro 255 fuel pump with coop fuel pump wiring mod
New fuel lines
4bar FPR fitted into rails
Aftermarket adjustable FPR mounted in engine bay( there for when mapping gets done)
Gtec 2 chipped ecu
Oil pressure and voltage vdo gauge mounted on dash
Full G-Reddy digital boost gauge and turbo timer
Electric push button start conversion
Racing steering wheel and boss kit fitted
Complete bose sound system upgrade in front doors and rear quarters
Shortened gear stick with Wicked gear lever
Front engine bay stabiliser bar
New bravo top mount conversion fitted with coilovers
Complete manifold and down pipe heat wrapped in titanium exhaust wrap
New Cambelt, waterpump, alternator belts
New lambda
New Maf
Baileys atmospheric dump valve
Reconditioned starter motor
Fully heat painted head, block and gearbox
New Cv Joints and boots
New trackrod ends and complete wheel alignment
Rear tinted windows with some alfa decals
Body work for its age is outstanding just needs a good detail
Ecu virginized so no code for keys
Well thats what I can think of so far if I remember anything else will post about it
Now ive only driven her for about 3 months and put about 400miles on the new engine so would need to still run it in.After 1000 miles first oil change and filter
then another 1000 miles and second oil and filter change then your good to go.It really is a treat to drive and pulls like a demon out of hell
She has 4 months tax and just under a years mot
Only bad points are no badges as was going to make customs and never got round to it
Central locking doesnt work but will supply new central locking kit with alarm
Now i have lots of spares to go with the car so will just put everything in the boot if you want it
I'm looking for around £3600 for her but open to sensible offers
No silly offers as alot of time and shed loads of money has been put into this car so whoever gets it is going to be one lucky alfa owner
1997
80 000
Mot: Feb 2015
Tax: 4months
Harlow Essex
£3600 neg
Gary 07758839639
Mods:
Lightened flywheel
New fuel lines
Gtec 2 chipped ecu
New lambda
New Maf
