Hi,
I'm selling my Robin Hood, unfortunately i'm moving house and won't have a garage so I need to switch to something I can leave outside.
MOT august 26th
TAX Aug 31st
Its the 2.0L (205 block) pinto with the progressive 32/36 webber side draughts, shortned sump.
I bought it off a friend i work with and its been nothing but fun. It wasn't running right so i re did the timing, new set of leads and plugs and now it flies.
I was going to convert it to bike carbs and partially stripped down the inlet side, but then changed my mind so its been rebuilt with new gaskets. (will throw in the manifold i had built and bike pump, also have a set of carbs but not convinced they are much good)
It has the full wet weather gear (roof and doors) which are very desirable and sell very quickly when they do pop up.
There is a digital dash, reads anything and everything you could want connected up, but currently isn't as i recovered the dash.
I also have a spare new steering wheel with sparco quick release fitting i was going to fit for added security .
There are a few electrical gremlins with the lights to be fixed, i wired in a couple of quick fix's but needs doing correctly.
Bucket seats are good if tatty, also 4 point harnesses.
Lots of fun and sounds great. Load of paperwork and manual for the dash. Ready to drive away.
Questions welcome.
Part Ex's considered but ideally cash.
MOT august 26th
TAX Aug 31st
Questions welcome.
