nofrills
my wings are made of Steeeeeeeel!!!
Mar 27, 2014 11:15:38 GMT
hi everyone, i have recently boight a set of lowering springs for my modern, and i was happliy going to fit them myself like i have done in the past on various other cars. But i have been warned that theses springs have a habit of fracturing etc etc....and that i should take my front shocks to a garage and let them change the springs over using a hydraulic press.... So does anyone have access to a hydraulic press in the chelmsford area that i could maybe pop in to change them over with beer tokens too :-)...
or shall i just have a go using my normal spring compressors.
thanks
Robin
Mar 27, 2014 15:15:25 GMT
Can't see how you would be able to do it on a hydraulic press for a start. Can't see how you could fracture a spring removing it, its not like a spring is fragile, there very un-fragile, thats the whole point of them. I would do it the good old fashioned way with spring compressors. Out of interest whats the car?
grumpy
Mar 27, 2014 15:33:13 GMT
Sounds a bit odd to me . If you have a decent set of spring compressors , beefy ones and not chad ones i don't see why you need a garage to do it .
taurus
Mar 27, 2014 17:55:22 GMT
A lot of modern springs do fracture, the failure rate is higher than on older cars. But providing you exercise usual caution you can use spring compressors safely. Wear eye protection and gloves, and keep the pressure as even as possible on both sides of the spring, you'll be fine.
Mar 27, 2014 18:02:29 GMT
its quite unlikely they will fracture as you are removing them, its the last coil which always breaks off, which is the one you can't get a compressor on anyway, so quite unlikely to cause you any issues.
Personally I would just crack on.
Mar 27, 2014 21:53:08 GMT
Mar 27, 2014 22:21:35 GMT
Never seen one of those before, just assumed we were talking about a regular hydraulic press. Learnt something new atleast.
Mar 27, 2014 22:32:29 GMT
Never seen one of those before, just assumed we were talking about a regular hydraulic press. Learnt something new atleast. In your defence the o/p did say 'hydraulic press' and not hydraulic spring compressor' which are two entirely different tools.
nofrills
Mar 28, 2014 12:45:02 GMT
thanks chaps, and yep i did say the wrong thing, apologies chaps, i have a good set of laser spring compressors, i used them on a st24 once and my old 20v marea (which weirdly enough use the same springs as the stilo). i will just crack on, alot of horror stories on the stilo forum of springs just going, but my idea is to compress slightly and undo the top nut asway from me, compress more and then undo the nut (like i did before) i was also thinking of buying a hydraulic spring compressor as there not that much, but then i will probably only use it a handful of times.
Thanks for your advice chaps
cheers
Robin
nofrills
Mar 28, 2014 12:46:54 GMT
Can't see how you would be able to do it on a hydraulic press for a start. Can't see how you could fracture a spring removing it, its not like a spring is fragile, there very un-fragile, thats the whole point of them. I would do it the good old fashioned way with spring compressors. Out of interest whats the car? its a fiat stilo multiwagon diesel, had it a few years and time to start doing a few bits to it to improve it
Mar 28, 2014 13:48:42 GMT
I've found spring clamps ok for light cars, used them on my Polo springs and Ford Capri, but changed the springs on my BMW E38 recently, the springs are huge and there was no way i fancied using spring clamps, took the springs and struts to my local indy BMW garage and he fitted them for £15 per strut.
Spring change on my modernChasR
@chasr
Club Retro Rides Member 170
Mar 28, 2014 18:01:55 GMT
I have used spring compressors on moderns before, but they can be a little touch and go. They will do the job but it is best to proceed with a little more caution you would with an older car.
You can get a decent floor mounted spring compressor for less than £100 and even if its used a few times it is money well spent. Once you have one you will find you have a lot more friends.
nofrills
Mar 31, 2014 13:50:15 GMT
You can get a decent floor mounted spring compressor for less than £100 and even if its used a few times it is money well spent. Once you have one you will find you have a lot more friends. yep been looking at these..... its £120 to have them fitted or i can buy this spring compressor and be £20 up but then also all my mates will want to use it.... or i may swap out the rears and then take it in to get the fronts done... not sure yet.... someone i know has just done his springs in the same car as mine and said it wasn't too bad
Not yet met a shock I couldn't change a spring on yet with good oil spring clamps personally haha but then again my middle name is "danger" hahah
nofrills
Not yet met a shock I couldn't change a spring on yet with good oil spring clamps personally haha but then again my middle name is "danger" hahah Same here buddy but this is the newest car i have owned lol
What's the worst that could happen ? Skip till end and obviously filmed on a fax machine with the quality
We have the very spring compressors as posted in the link above and they're worth their weight in gold.
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
