Mar 25, 2014 20:23:35 GMT
Hi All ,
Any help at this stage will be most appreciated
I bought a vauhall senator recently and on the drive home (30 miles) it was fine . Once I pulled up it started to get warmer and warmer .
I then got a mechanic to look at it and I have changed the thermostate and Water pump under his advice .
It has not cured the problem .
I wonder if anyone knows any way of checking teh head gasket or other possible causes .
I have flushed it and put in anti freeze , and still no change .
the vicous fan is always rotating and the fan in front of this comes on at 105 degrees as expected .
please help
If i cannot solve it I will cut my looses and sell it for parts - which is a slight shame.
Any advice will be much appreciated
regards
Samuel
bobman
Mar 25, 2014 20:41:28 GMT
Google coolant dye test you can get kits or any half decent mechanic with appropriate equipment
Mar 26, 2014 15:24:07 GMT
what engine? 24v?
The head gasket is gone on my 24v and its a massively expensive job to sort sadly so I'm binning the engine when it gives up altogether and going 3.0 V6.
87 Mk2 Cavalier SRi Turbo
89 Mk3 Cavalier SRi V6
90 Cartlon GSi3000 24v (Lotus Rep)
90 Senator CD 24v
99 Omega 3.0 MV6
Mar 26, 2014 16:48:56 GMT
Yep 24 valve .
Just bleed it all again this morning - started it an took about an hour 20 mins and it started to overheat again - its quite strange I think .
grumpy
Mar 26, 2014 18:13:54 GMT
Is the thermostat in properly ? Compression test ?
Mar 27, 2014 12:18:01 GMT
put a new thermostate in m8
Colonelk
Club RR Member Number: 83
Mar 27, 2014 13:03:09 GMT
Sniff test will tell you if the headgasket has gone (to cylinder) I believe most garages can do this.
I know a lot of people who have fitted new thermostats and they have proven to not work. Only way to tell if put them in a pan of water and heat them up. Is it only overheating when stationery or just after a long period driving? is it loosing water?
Mar 28, 2014 14:58:15 GMT
Not lossing water , and overhets mainly when stationary and after about 50 mins , when driving along it seams fine
I have ben told it is a common thing of teh 24 valve senators
Mar 28, 2014 16:01:43 GMT
You checked the water pump shaft hasn't snapped letting the impellor just spin ?? An hour and 20 mins is a long time for a head gasket as usually they boil up after 5-10 mins usually if hg has gone ??
Worth checking pump impellor IMHO if its easy enough to do so
if the header tank has a small return feed (usually top of tank) take it off and hold the car at 3000rpm you should see a flow of steady coolant coming out if not possible water pump or airlock and at worst hg
taurus
Mar 28, 2014 17:21:56 GMT
I doubt that's a HG problem. Since you've fitted a replacement 'stat and water pump I'd go for a partially blocked radiator. Take it out, fill it with cheap coke overnight, then flush it and try it back in the car.
is it actually over heating (firing water out the top,steam etc etc) or are you going by what the dash is telling you?
'88 Cadillac Brougham hearse (white) '91 Carlton GSi 24v '72 Dodge dual cab pick up '99 Mercedes S55 AMG
djefk
I doubt that's a HG problem. Since you've fitted a replacement 'stat and water pump I'd go for a partially blocked radiator. Take it out, fill it with cheap coke overnight, then flush it and try it back in the car. Agree with this, sounds like the rad is partly blocked, meaning the fan can't do its job properly when the car is stationary but there's enough airflow through the whole rad (just) to cool it down when moving. Does switch the heater and blower on full make any difference? On some cars the heater is powerful enough to act as a secondary radiator (unless that too is partly blocked!), although on 3 litre Senator maybe not!
breng
I had the 12v model with the same symptoms as yours.
Viscous fan was goosed.
......or radiator fins are corroded and missing/fallen out?
