Shed/garage/car clear out due to a house move so everything must go. Collection from Tunbridge Wells or might be able to sort collection from Hertford or Billingshurst. Otherwise prices are plus postage unless otherwise stated. Will consider offers.
1x Stromberg 150CD in good condition, has been rebuilt using a rebuild kit with all new gaskets and o-rings, but obviously would need setting up. £25
(see bottom of thread)
1x Stromberg 150CD, stripped but complete and comes with rebuild kit and another 150CD in bits for spares. £15
2x OHV Delco distributor, centre drive. Might need cleaning and comes with vac but not necessarily anything else. £15 ea
1x OHV Delco distributor, offset drive. As above. £15
1x OHV fuel pump. Looks brand new but I think someone's put an adapter piece in the outlet and stripped the thread. £5
1x Viva horn from an OHV. £5
1x water pump/fan pulley, solid type. £5
1x ignition switch that's been chopped about, but could be repaired and may still be useable. £5
1x OHV +0.030 big end bearings, AE. £15
1x OHV sidedraught inlet manifold, think there might be a second too. £10 ea
1x OHV radiator in very good condition. £35
1x HC Passenger side rear light, very good condition £15
Random bits of wiring and bulb holders, tell me what you need. See photo below. £3 ea
1x HC rear view mirror bracket. £5
Random clutch cables - I'll try to find out what model they come from, see photo below. £5 ea
1x HB(?) interior door handle. £5
1x OHV master cylinder without failure switch. £60
