I am trying to get a new clutch for my ford Anglia. The engine is a Ford 1500GT, from a Cortina, year unknown.
Anyone know if they differ over the years? I suspect they do.
Here's some info on the clutch.
Centre plate has 57735 on one side and 57734 on the other. The centre plate is 190mm diameter. It has a 20 splined shaft, which is approx 19 or 20mm diameter (3/4"?)
The pressure plate has flat fingers, not shaped
It has 6 bolt holes, in pairs, 220mm diameter, with a dowel pin between each pair.
Any help appreciated
