Onne
Hello all The Benz is struggling to idle (sometimes!) on both petrol and gas. It feels like it is hunting a bit. My diagnoses is that the IACV is dirty. It is easy enough to get to, but what is the best method to clean it? Can I semi-submerge (keeping all electrics dry) it in some brake cleaner/carb cleaner? What is the best way to get rid of stubborn carbon deposits? Have a W126:
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
I used some carb cleaner on my xr2i which worked a treat
taurus
I use Quicksilver Powertune - made for powerboat engines. It's like carb cleaner on steroids. It's the best thing I've found for cleaning ICVs and throttle bodies. If you don't have a boat chandlers near you then buy it on ebay.
Brake or carb cleaner, the electronics are away from where you will be cleaning anyway so you are unlikely to damage anything.
any solvent seems to work , carb cleaner /petrol etc
some folk leave the wires on so its still buzzing and dunk it in a jar of solvent ** take care if you do this**
Cleaning Idle Control ValvesChasR
@chasr
Club Retro Rides Member 170
any solvent seems to work , carb cleaner /petrol etc some folk leave the wires on so its still buzzing and dunk it in a jar of solvent ** take care if you do this** C'mon, no nuns or kittens will die with this kind of thing though . Carb cleaner and rinsing has always worked well for me on other cars with an iffy ICV. I am trying to think what the ICV look likes on a K Jetronic car now!.
yeah ive never killed any kittens with that method , but just saying like
kjet ones are usualy a tube with a leccy plug on one end...just dunk it in a jar with the wires on and ign on for a bit
Onne
Cheers chaps, I'll get some cleaner of sorts and give that a go. The ICV is 200k miles old after all!
I soaked min overnight in petrol.
