LowStandards
Club Retro Rides Member 231
fuel consumpsion puts me off a little, the 1725 is a lil thirsty for a daily driver, thats the other thing, it would be my daily hmmmmmm I get 30mpg out of mine on a run, and thats fully laden with camping gear! The bloke i bought her off used her as a daily round Newcastle! So they can handle it!
One from NZ Awesome picture... Thats low! Loving yours Dez, fancy doing Chloe? Slam-fest! ;D
Apr 16, 2007 10:42:10 GMT
One from NZ Thats low! Loving yours Dez, fancy doing Chloe? It looks like one of those fancy space loos you get on the High street. Where does the 20p go in?
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
coxy
The 4 Ring Mafia!
Apr 16, 2007 12:24:32 GMT
6 inches??? you girl! you have let yourself down! with built in skirts and factory narrowed front I expect the height to be in negative figures!! ;D ;D ;D ;D ;D
Apr 16, 2007 12:36:46 GMT
ur commer looks sweet mate, would love to see it in purple metalflake paint.
Dez
Club RR Member Number: 34
low commer- ive done it.Dez
@dez
Club Retro Rides Member 34
Apr 16, 2007 14:04:17 GMT
One from NZ Thats low! Loving yours Dez, fancy doing Chloe? I call photoshop, unless theres a 4" hole in the floor for the sump and X-memeber even if he'd taken the front springs out, the front would sit 6" higher than that with that size tyre. either that, or its channelled. ive already got one guy asking me to do his, thing is with the amount of work involved to do it, especially the rear end, itll cost about 750-800 to drop one, which is more than most people paid for theirs in the first place! still its probably less than dropping a vw the same amount.....
Last Edit: Apr 16, 2007 14:05:16 GMT by Dez
Davenger
It's only metal
Club RR Member Number: 140
low commer- ive done it.Davenger
@dminifreak
Club Retro Rides Member 140
Apr 16, 2007 15:23:32 GMT
Winner!!!!!!!!!!!!!!!!! That looks awesome mate
SteveP
300 Maniac
Apr 16, 2007 16:01:50 GMT
until I can find a donor 740/760/940/960 vulva with a 2.3 16v turbo lump for this and a 4.10 ratio lsd rear axle for the merc I wish you luck, the 16v turbo (only in 2.0 form) never came to the UK So you'd have to go for an 8v block and 16v head and there are some issues with that iirc. 16v's don't necessarily produce more power anyway - most of its just for pimp value Best choice would be a late 940 B230FK block which has oil squirters and 13mm conrods, as its low boost it will have had a very easy life! That Commer stance though... sits perfectly
Last Edit: Apr 16, 2007 16:04:27 GMT by SteveP
2003 - Volvo S60 D5 SE (Daily) 1989 - Volvo 360 GLT 1985 - Volvo 360 GLS
Apr 16, 2007 16:05:04 GMT
That one from NZ is a pshop. Look at the shadow at the rear, much longer than the front bumper one is, there's other clues too!
Peugeot 307sw - Suzuki SV650S - MX5.
slater
Club RR Member Number: 78
low commer- ive done it.slater
@slater
Club Retro Rides Member 78
Apr 16, 2007 17:29:58 GMT
One from NZ Thats low! Loving yours Dez, fancy doing Chloe? HA! read it and weep you 'rat look' splitty owners! youve been out done by miles!!! ;D
Apr 16, 2007 18:08:52 GMT
Brilliant, i was never that keen on Commers as the axles looked so narrow, and it was always old folk ot BT engineers i saw in em! I'm really feeling the love for em now though, we know all too well anything can be fixed with modded springs and some choice wheels and accessories. Looks ace!
amazagon
Amazons are go
Apr 16, 2007 18:44:17 GMT
Isn`t that Freddie Flintstones new work van? surely the floor must be missing to go that lo ;D
hey dez could you please e-mail on: rolamad@hotmail.com
Cheerz
Ether
Apr 18, 2007 11:11:52 GMT
Could someone please post the picture of the Commer on dished wires?
Apr 18, 2007 21:25:53 GMT
This is one from new zealand 2. Who owns that sacked/photoshoped blue one?I'm keen to get in contact with him.
VWDan
VW Jetta MK1, VW Caravelle 1.9TD, Audi A6 Tdi Avant
Apr 19, 2007 18:25:31 GMT
When you say 'spring over axle' do you mean like this: And basically you fit the axle on top instead of underneath the leaf spring to make it 'spring under axle'? I guess you need to use extremely strong U bolts to keep it in place then? Any other mods needed - i'd guess shorter shocks would be one thing required. Front suspension on the LT looks like this: Can't see that you'd be able to take much out of the springs as there arn't that many coils. And looks like the shocks are inside the coils too. Now where's that mig welder gone.....only kidding
If only everything in life was as cool as a retro VW racer.
Dez
@dez
Apr 19, 2007 19:53:53 GMT
yes thats spring over axle. youre absoloutely fine using normal suspension grade (10 or higher) U-bolts for axle over setups. but to be honest mate, youre rear suspension setup, especially the leafs, look totally shagged!
id also wager your front bumpstops are so close to the arm cos your front springs are sagging, thats very close for a stock setup, the commer has more than that now ive lowered it 4"!!
Apr 19, 2007 20:16:43 GMT
it looks like the leaf springs is upside down
Dez
@dez
Apr 19, 2007 20:38:18 GMT
some of the mods required to get the commer this low- it actually sits about 1.5" lower at the back now than it was in the pics don't worry about the size of the notch, it has box section welded onto the chassis rails from above for re-enforcement. you can also see the 'diff bulge' in the floor in the pics, made out of one of the old hubcaps ile post pics of the other bits I had to do when I get chance.
Last Edit: Apr 19, 2007 20:40:01 GMT by Dez
VWDan
Apr 19, 2007 20:52:49 GMT
You wanna see how it leans in the corners too - feels like its gonna topple over I've gotta say i was looking at it the other day and wondering why the springs bend upwards when i was sure that they should bend the other way. Looks like it runs on the rear bumpstops all the time too, unless its supposed to be like that. Hmm, what to do next
