Hi all,
I'm thinking about knocking up a custom dash for the imp- hopefully it'll be a job I won't be able to balls up
Anyways, at the moment, the dash is just......
Oil light, battery charge light, speedo, fuel, water temp, and I think that's it.
I want to use Smiths gauges, so will they pretty much be a straight swap for the ones that are already there? Or will fettling be required? And will any smiths gauges be ok? Any recommended ones in particular?
Also, I've seen electrical, and mechanical gauges for the same type of gauge. What's the difference exactly?
Lastly (for now).... oil pressure gauge- how do I go about fitting a sender? I'm assuing there's some sort of sender/switch already as there is a light? and what about oil temp should i decide to fit one of those as well?
What I want to have is oil pressure gauge, water temp, speedo, tacho, fuel gauge, indicator light, main beam light, oil light, battery light. The lights I'm going to get from Car Builder Solutions I think becuase they look quite nifty! Might even fit a vacuum gauge, just in case I need reminding how far down my right foot is!
'Course, if I decide to go for the uber gauged up look, might as well get an ammetre and volt metre in there as well!
Any other recommendations other than smiths gauges? Need to be easliy obtainable second hand, and/or cheap!
Haha, I love my "form over function" way of thinking
