sorry for the cap locks copied from my ebay lol
1986 FORD CAPRI 1.6 FINISHED IN GLOSS BLACK
SHE HAS COVERED 63154 GENUINE MILES
WAS LAST ON THE ROAD AT THE END OF DECEMBER 2002 SINCE THEN SHE HAS BEEN STORED IN A DRY GARAGE
SHE HAS BEEN FULLY RECOMISSIONED AND PUT THROUGH THE HER MOT
COMES WITH A FULL MOT TILL 13th OF FEBUARY 2015 WITH NO ADVISORYS
2 PREVIOUS OWNERS
ALL THE BRAKES WERE OVERHAULED
THE ENGINE HAS BEEN SERVICED
FITTED WITH THE 1.6 PINTO ENGINE ALONG WITH THE COMMON UPGRADE OF THE SINGLE CHOKE WEBBER CARBURETTA WITH MANUAL CHOKE WHICH WORKS AS IT SHOULD
THE ENGINE RUNS VERY WELL WITH NO NASTY NOISES
THE RADIATOR WAS FLUSHED AND RE FILLED WITH FRESH ANTI FREEZE SO THERE ARE NO HEATING ISSUES
ITS FITTED WITH THE TYPE 9 FIVE SPEED GEARBOX WHICH GOES AND PULLS THROUGH ALL THE GEARS AS IT SHOULD
SHE BRAKES AS SHE SHOULD AND THE HAND BRAKES WORKS AS IT SHOULD
ALL THE suspension IS SPOT ON WITH NO SAGGING POINTS
SHE IS FITTED WITH A TOW BAR THE PREVIOUS OLDER GENTLEMAN THAT OWNED THE CAR USED IT FOR TOWING A SMALL TRAILER TENT AROUND THE UK ON HOLIDAYS
I CARNT GARUNTEE THE ELECTRICS ALL WORK AS I HAVE NO WAY OF TESTING THEM
SHE IS FITTED WITH THE STANDARD LASER ALLOYS WITH GOOD TYRES THERE IS FIVE OF THEM
THERE IS THE ORIGINAL JACK IN THE BOOT TOO
INSIDE ITS FITTED WITH THE STANDARD LASER INTERIOR WHICH IS ALL IN GOOD CONDITION
SUNROOF WORKS ON BOTH TILT AND SLIDE
THE HEATER IS A LITTLE TEMPREMENTAL SOMETIMES IT WORKS THEN OTHER TIMES IT DOSNT
THERE ARE REAR SEATBELTS THAT WORK
ALL THE GAUGES WORK AS THEY SHOULD
FITTED IS THE STANDARD FORD STEREO WHICH ALL WORKS AS IT SHOULD
ALL THE LIGHTS WORK AS THEY SHOULD
THE CARPETS ARE GOOD WITH NO HOLES IN THEM THEY COULD DO WITH A GOOD SHAMPOO MAINLY THE DRIVERS SIDE
THE DASH HAS THE USUALL CRACKS ON THE TOP WHICH IS COMMON ON THESE
ON THE OUTSIDE SHE IS IN VERY VERY GOOD CONDITION SHE HAS A REALLY NICE SHINE TO HER IT HAD A REPLACEMENT PASSENGER FRONT WING A FEW YEARS BEFORE IT WAS PARKED UP BUT FITTED WELL
THERE IS THE ODD MARK/DENT HERE AND THERE BUT NOTHING MAJOR AND CONSIDERING HER AGE ITS NOTHING AT ALL
UNDERNEATH THE CAR IS IMMACUALTE THERE HAS NEEN NO WELDING NOR DOES SHE NEED ANY THE SPRING HANGERS FRONT AND REAR ARE IMMACULATE
THE UPPER A POSTS ARE VERY VERY GOOD ALONG WITH THE SILLS,ARCHES AND THE OPENING PANELS
THE FRONT WHEELS COULD DO WITH A BALENCE AS THERE IS A BIT OF WHEEL WOBBLE BUT THIS IS MOST LIKLEY THE DIFFERENT SIZE WHEEL NUTS BUT I THINK I HAVE SOME SPARE ONES I SHAL HAVE A LOOK
THE V5 WILL NEED TO BE APPLIED AS IT WAS LOST BY THE PREVIOUS OWNER
A FULL RECIEPT WILL BE GIVEN ALONG WITH PROOF OF ID AND ADDRESS
OVERALL THE CAR IS IN VERY VERY GOOD CONDITION NOW I'm NOT SELLING IT AS A SHOWCAR BUT THERE IS POTENTIAL TO BE ONE
THERE ISNT MANY CAPRIS FOR THIS MONEY IN SUCH GOOD CONDITION
ANY INSPECTION IS WELCOME THE CAR IS AT MY HOME ADDRESS AND IN A WELL LIT GARAGE SO SHE CAN BE VIEWED AT ANY TIME
TEST DRIVES WILL BE LIMITED AS SHE ISNT INSURED OR TAXED
IF YOU REQUIRE ANY MORE PHOTOS PLEASE FEEL FREE TO ASK SAME IF YOU HAVE ANY QUESTIONS JUST ASK EITHER BY PHONE OR EMAIL THROUGH HERE
I MAY BE INTERESTED IN A SMALL PART EX IF IT HELPS OR IF YOU HAVE AN ABANDONED CAPRI
£2300ono
2 PREVIOUS OWNERS
£2300ono
