Model: Range Rover 3.9 EFI petrol V8
Year: 1991
Mileage: 179500
Tax: to the end of may 2014
MOT: 5th April
Price: £1200
Ive owned this Range rover since and of September/start of October last year. But having too many projects on the go that I need to get finished for the show season, the range rover isn't getting used as much as it should, so its time for some one else to enjoy it
Spec.
The rangey is fitted with a 2inch suspension lift kit
Rebal underbelly guard
Front and rear diff plate guards
Removable tow hitch
Wolfrace alloy wheels
Winch front bumper (no winch fitted)
Electric front seats, electric windows
Good Points.
Waxoiled chassis, from what I can see I cant find any welding patches or any areas that need welding.
Changed the front and rear diff oils about 4 weeks ago along with the fuel filter
Recent engine oil and filter change, and spark plugs
Headlining is not sagged at all
Brand new tailgate gas struts
Bigger tyres fitted (standard alloy as spare)
two second hand spare front wings
the original air filter will be fitted
Looking through the paperwork that came with the car, its had new front swivel housing gaskets, and various other bits and bobs done
bad points.
Very small slight blow from exhaust manifold gaskets (sounds like the nearside bank of the engine)
A/C has been disconnected at some point in its life
Slight leak on screenwash bottle (light flickers on the dash now and then, screen wash still works fine)
no radio
drivers front window sticks abit when going up
heater only works on fan speed 3
the sunroof works but has been taped shut since I have bought it (previous owner taped it up) I don't know is it leaks or not, as I haven't tried to remove the tape.
the hole in the last picture is where the spare wheel sits, been like that since I bought it, I treated the metal surrounding it with kurst, that's why it looks darker then what it is
driver seat back tilt wont tilt forward but will tilt back and slide back and forth, passenger side works fine.
Passenger front door, you have to use the handle on the outside slowly as it latches itself locked again if opened hard, if that makes sense.
Any questions please feel free to ask, just trying to be as honest as I can with the advert I've proberly forgotten something.
