I brought this car only a few months back in the view to my girlfriend having it once she passed her test however a slight oversite on my part means two things, the insurance is just to much for a new driver and its slightly too big for her at this stage!
Anyway its a good old relaible focus with the hardier 1.8 lump.
Has electric windows, Remote lcoking and Air-con which all works
Its a little tatty here and there but its all purely cosmetic!
MOT - September 2014
TAX - July 2014
Miles - 77000 (may go up slightly)
I have carried out the following work on it as i was planning on keeping it for a good few years:
I work for Ford so its all been done properly
Full service including - Oil, Oil filter, Fuel Filter, Spark plugs, Air filter and Pollen filter
New alternator Including AUX belt (the old one wasnt charging properly)
Cambelt has been replaced Inc Tensioners and idlers
Replaced PAS fluid as the old stuff was black!
New front drop links to cure a knocking noise i was getting
Replacement Airbag module as the other one decided it had had enough!
The only bad points which i know of is -
the passenger front door lock is sometimes a bit lazy and it take 2 or 3 attempts to lock the car, i have another latch which i will supply.
There is a bit of lacquer peel on the bonnet and a few dents/chips around the car but as i said all cosmetic and no rust at all!
