123000 miles from new with FSH, 2 owners, MOT Dec 2014, Tax till end of April.
I bought this for my girlfriend as she wanted a cheap runabout as she was planning to sell her MK3 MX5, I put a new clutch kit and slave in the car and gave it a good clean. The car then went in for the MOT and had new front wishbones with ball joints and rear bushes, it had new solid brake lines run to the back of the car due to corrosion, new front flexi hoses and complete system bleed, new disc’s and pads on the front, 2 new tyres ( I have a pair of nearly new matching for the other 2 wheels as well), at the same time it had new oil and filter. The roof all works but is a bit stiff on cold days and sometimes needs a helping hand to make sure it’s sitting down all the way to allow the rear cover to close properly. As you can see I've spent a fair amount doing everything it needs.
Bad points
There is a small oil leak from the front seal of the engine, not a big job but not had time to do it.
There is a bit of rust around the screen, rear arch and slight bubbling under the rear lights.
Passenger side window doesn't work, it could be a bad connection somewhere, unsure as haven't looked into why.
On the whole it’s a good car, drives nice and tight with good suspension, will be great fun in the summer months but since buying it for her my girlfriend has changed her mind and wants to keep her MX5 now.
£925 ovno
07833 704 583
Bad points
£925 ovno
07833 704 583
