rod
Apr 12, 2007 19:31:57 GMT
I know this has sort of been covered in other threads ,but..... Ive been looking at 2cv adverts .Need a car that I can use as a run around (tescos,kids etc)So that I don't have to take my other car out and get it dirty /wet (I'm not joking ! ;D) Anyways ,i thought one of these beasts may fit the bill,(cheap tax /poss cheap insurance /sunroof!!)BUT they all seem so expensive !!Whats going on with them ? I don't really know what to look for re the dodgy bits anyway! Will I get one mot'd for £500??
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Apr 12, 2007 19:37:07 GMT
you might get one thats MOT'd for that is the answer. They have become a bit sought after in some circles mate, almost have a scene tax on them too now. As mentioned before you should be able to get a dyane for that money but they are rarer and for sale less often than 2CV's A quick scout of the owners club mag this month reveals..........................not one MOT'd car for less than 995. couple of fixers up at 200-500 bracket. Cheapest taxed and tested car is a dyane at 600 quid. Just so you know
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Apr 12, 2007 19:47:14 GMT
Prices seem to be going nuts at the moment, my first 2cv was £10, my second was £500 with 12 months tax and test, then the last one was £1000 (very nice example when I got it) Nowadays a solid and roadworty example will set you back £800-£1000 easy Very good original cars go for around £1800-£3500, complete rebuilds on galvi chassis... well I've seen them from £2500 to £6500!!!!! As for what to look for, check for rot on chassis first (best to go for one with a replacement galvanises chassis), check front floors and bulkhead and VERY importantly rear inner wings for rot. If the car feels stupidly heavy to steer or has large gaps between the front panels then this is usually a first indication that the chassis is sagging and about to go. Aside from that check everything you would on a normal motor and you should be ok.
rod
Apr 12, 2007 19:47:15 GMT
Hmmmmm!I don't really care if it is a Dyane ..Is that like the blue one you had for sale? Just really looking for an instantly useable run around ,don't want a speed machine ...gonna have to sit and think about it a bit more ! Still looking at a couple of other makes .
Apr 12, 2007 19:53:42 GMT
Dyane is basically a different shell on 2cv running gear rod, either FTW ;D
stinkwheel
Apr 12, 2007 20:07:11 GMT
Rod,
yes the blue one was a dyane.
