Jan 27, 2014 21:39:50 GMT
Seth
Jan 27, 2014 21:44:26 GMT
Stunning! A rare car in Croatia I imagine. Those floors looked to be in damn good condition! Is it staying standard or have you any modifications planned?
Jan 27, 2014 22:44:49 GMT
Nice project, a great solid base by the looks
Jan 27, 2014 22:45:10 GMT
Jan 28, 2014 11:41:08 GMT
Thanks It's prety rare car in Croatia. They is just few of them still on the road. Bodywork was in good shape. There was just few rust places which i needed to repair. For now I plan to keep it original without modifications. Later, after I finish it maybe I install som new wheels, and two strombergs carbs, but I don't wan't to go far from original state.
Davenger
It's only metal
Club RR Member Number: 140
1974 HIllman Avenger 1300Davenger
@dminifreak
Club Retro Rides Member 140
Jan 28, 2014 19:13:11 GMT
Looking good. Hope my Avenger looks that good when It's straightened out
Jan 28, 2014 19:26:00 GMT
a very tidy & rust-free looking avenger! i guess the weather was kinder to them in croatia
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
1974 HIllman Avenger 1300retrolegends
@retrolegends
Club Retro Rides Member 94
Jan 28, 2014 19:29:59 GMT
That looks great, keep up the good work.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Jan 28, 2014 19:55:09 GMT
That's a very tidy Avenger you've got there. Wish mine was as solid as that. Keep us all up to date with the project, can't wait to see it when it's finished.
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
Jan 28, 2014 21:04:52 GMT
Nice to see another avenger on here:)
Jan 31, 2014 20:42:53 GMT
Agree with AvengerTec: Nice to see another Avenger around! (besides its named different) What a good shell you have. I hope mine were half as good as yours!
FJSigma
1989 Volkswagen VW1500 (The argentinian Avenger)
Mar 27, 2014 10:45:45 GMT
Mar 27, 2014 11:07:22 GMT
very nice repair!
Citroen HY 1962 Toyota CROWN MS75 1972 Toyoya CROWN MS75 1973 Toyota CROWN MS67 1972 Toyota CROWN RS56 1968 Toyota CROWN MS57 1969 Datsun 120a coupe 1975 VW LT31 1995 Volvo XC70 cross country 2007
Mar 27, 2014 11:23:45 GMT
This is looking just great... Keep up the good work!
***GARAGE CURRENTLY EMPTY***
Mar 27, 2014 20:39:29 GMT
WOW!! That's great work repairing and recovering. Cracked dashboards such a common problem on both Chrysler/Talbot Sunbeams and Hillman/Chrysler/Talbot Avengers. I don't think I've owned an Avenger or a Sunbeam that hasn't had a cracked dash top.
Keep up the excellent work.
Davenger
It's only metal
@dminifreak
Mar 27, 2014 23:55:30 GMT
That's brilliant! Have to try that on my Avenger
jpsmit
Awesome work. Would you mind describing a bit what you did with the dash (in addition to the pics) i have a dash repair in my future.
vegar
Thats a nice looking Avenger. Great color also I have only seen one Avenger in Croatia before, and that's a dark blue located in Jablanac where the ferry goes to Otok Rab. It's been there for years, and it's still in traffic, at least it was last summer
pugmyster
Iam not old iam retro
Mar 28, 2014 15:12:46 GMT
a very good paint finish aswell, was it painted by you in your garage or out in the croation sunshine will be a very nice car when its all back together again,
Mar 28, 2014 22:20:17 GMT
Awesome work. Would you mind describing a bit what you did with the dash (in addition to the pics) i have a dash repair in my future. I used PU (polyurethane) foam for crack filling. You can find this foam in all stores with construction materials (its used for door window and styrofoam montage). Just be careful because its very sticky, and expandable. When foam was dry I removed ecxess material and smoothed it with sandpaper. Pink layer is wrapping material for PC motherboards and graphic cards I work in computer service so I have a lot of this material. I used it because when I removed all bad material from console it had sharp edges and unevenness so with this material I got smooth and even surface which is soft on touch. You can find similar material in construction stores (It's used for laminate flooring, and it goes under the laminate). I glued this material on console with glue that can resist higher temperatures because console is under the window and can be vwrry hot (I used Patex glue and I think it is for teperatures up ti 80 C) Vinyl is from two peaces. I managed to strech bottom part without cutting it. Top part was bigger problem and I needed to slice vinyl on left and right rounded part and insert new smal triangle of vinyl to fill the space. (I tought it will be verry vissible, but it looks OK). Vinyl is glued with same glue I never done this before so I spend enough material for two consoles, and I allmost gave up because I tought it will look bad so I'm glad you liked it I hope I helped you.
