For my Marlin I want steel wheels and see the MGF has the same PCD so a set of spare wheels off them would be ideal. Looking on eBay I see such a wheel in mint condition with as new quality tyres is a fraction of what even just a cheap new tyre would cost. I notice however the wheels have an 80 sticker. AFAIK the tyre is a normal item and not a space saver - is this correct ? Am I right to assume the 80 sticker relates to use on an MGF which will have different size and type of tyres on the other corners so it's marked such for emergency only to be legal ? Thanks. Paul h
Jan 18, 2014 10:01:44 GMT
Yes your thinking is correct, the limited speed is regarding the tyre and not the wheel itself.
1965 Morris Minor 1000 soon to be 1380 1997 MK1 MX-5 1.8 (sold) 2009 MK3 MX-5 2.0 (sold) 2008 Mini Cooper (sold) 2003 Mini Cooper S (sold) Fixed wheel Raleigh Clubman (sold) 1982 Yamaha RS125DX (sold)
Jan 18, 2014 10:03:39 GMT
And as your newly acquired Marlin will be significantly lighter than the MGF there should be no problem. On a similar note are the wheels on the rover 214/216 the same stud pattern as the MGF?
Rich
Club RR Member Number: 160
MGF steel spare wheelsRich
@foxmcintyre
Club Retro Rides Member 160
Jan 18, 2014 11:03:27 GMT
And as your newly acquired Marlin will be significantly lighter than the MGF there should be no problem. On a similar note are the wheels on the rover 214/216 the same stud pattern as the MGF? No, the MGF is 95 pcd and the 200/400 is 100 pcd as stated I think the speed restriction is due to the odd sized wheel combo using it induces. Worst case scenario the tires on the wheels are low rated and you'll have to fit different tires.
Jan 18, 2014 11:59:45 GMT
Think I need to see an actual MGF wheel and check out any information on the side of the tyre. I assumed normal 175/65/14 Goodyear but suppose it could be a version of a spacesaver.
Paul H
Jan 19, 2014 21:56:49 GMT
The tyres are a standard tyre. In fact the steel wheels and the tyres were the same as fitted to late maestro and montego models. The sticker is just because the tyres on the front were 185 and 205 rear, on at least a 15" rim, hence the warning sticker.
Jan 19, 2014 21:57:11 GMT
PHUQ
Jan 19, 2014 22:04:44 GMT
I had a pair on the back of the Estate for a while and spectacularly failed to die, it's that's any help? Mind you, I don't think it's ever been 80mph... As said above, they are "normal" wheels and tyres and will be just fine
Jan 20, 2014 10:38:08 GMT
I may be wrong on this, but I always thought the '80' referred to 80kmph (nearer 50mph)?
As mentioned, this is largely because many spare wheels are of a different size to others on the car, so you'll have two different sizes across an axle. Technically illegal, except as a 'get you to a garage' scenario. The restriced speed means you shouldn't be running around indefinitely on a different sized tyre doing your normal speeds up and down the motorway (for example).
It's also, I believe, because it standardises the recommended speed for spares that aren't the same size as the standard tyres on the car, even if the speed rating for that particular tyre is set higher. This is more imortant when considering some of the really skinny space savers or even some of those mad inflating ones. They really shouldn't be driven fast on due to their construction, load VS speed rating and massively increased handling differences to the standard tyres (ever gone into a damp corner a bit fast with a skinny space saver on the front??), so the speed rating has been generally set at 80/50 across pretty much all 'non original size' spares to cover all bases.
Jan 20, 2014 11:59:33 GMT
I had a pair on the back of the Estate for a while and spectacularly failed to die, it's that's any help? Mind you, I don't think it's ever been 80mph... As said above, they are "normal" wheels and tyres and will be just fine Did they fit on rear without spacers ? What about the front - did you try them there for clearance as well ? Cheers. Paul H
PHUQ
Jan 20, 2014 12:26:56 GMT
They were fine on the back- they are a more sensible offset than the alloys I think. I only ever had a pair (and don't have them any more sadly, in fact I think they got weighed in in a tidying spree). Not convinced they'd have gone straight on the front.
