slammed 66
www.gtturbo.org
Random thoughts going through my head on how to propel my viva. I know Si fitted the cavalier 1.7 derv to his but there's an abundance of peugeot dervs available and can make quite fruity power.
The only issue would be the gearbox and size of the tunnel.
Years ago a friends dad had an ldv with a pug lump in it but I assume an ldv box would be huge. Are there any other options?
Thanks
86 Renault 5 GT Turbo 89 Renault extra 91 Skyline GTR 98 Mini 1275 mpi 99 Autech Rider www.gtturbo.org
benzine
Club RR Member Number: 87
Jan 16, 2014 11:51:57 GMT
Pilot box on XUD. Seems about an average sized gearbox to me. Easy to sort out flywheel + clutch Tata loadbeta gearbox on XUD. Bellhousing is a better, more compact shape than the Pilot box. They seem to be more expensive to get, harder to get and unknown how much power they'll take for how long. Not sure about clutch/flywheel/pressure plate issues yet (this is going in a friends morris minor and he's not got round to clutch yet)
Last Edit: Jan 16, 2014 11:53:35 GMT by benzine
Jan 16, 2014 18:40:44 GMT
not a beast of a gearbox - but it's not exactly a paperweight either! Parts to fit: XU/XUD engine of your choice (XUD11 pictured) LDV Pilot gearbox LDV Pilot crankshaft spigot bearing (approx £5 from a DAF dealer) pug 306 HDi flywheel, with clutch pressure plate Ford Galaxy 2L clutch friction plate hydraulic clutch slave cylinder - LDV pilot type was used in many vehicles (in my case,the scimitar one was identical!)
v8ian
Jan 16, 2014 18:55:16 GMT
That LDV box is the Rover LT77, or possibly R380.
omega
Jan 16, 2014 19:00:47 GMT
there is another option for a pug rwd and its small and takes a lot of power
suzuki
Jan 16, 2014 19:05:24 GMT
That LDV box is the Rover LT77, or possibly R380. A point of debate by most - from what I could find, it seems to be an R380 (reverse sensor is the the gearbox, rather than the gear selector housing bit)
v8ian
Jan 16, 2014 19:37:28 GMT
Reverse on boxes are on opposite sides, and the R380 is generally thought to be stronger, I never broke a LT77 in 5 years of drag racing one,
