Dec 15, 2013 10:01:54 GMT
OK lets assume there is no suitable autobox for the K Series so what about the Zetec then ? Anyone know if the box from, say, a late model Granada will fit ?
Thanks.
Paul h
v8ian
Dec 15, 2013 10:17:19 GMT
Did Mazda MX5s come in auto?? that may fit??
Dec 15, 2013 10:52:06 GMT
OK lets assume there is no suitable autobox for the K Series so what about the Zetec then ? Anyone know if the box from, say, a late model Granada will fit ? Thanks. Paul h You can use the autobox from a 4cyl sierra or granada, those bolt up to a zetec no problem.
Copey
Dec 15, 2013 10:59:26 GMT
As above, find a box from an auto sierra or Granada that used the dohc motor
Dec 15, 2013 11:36:05 GMT
Thanks for replies. Now I can make plans knowing something is possible Paul h
gavs1
Dec 15, 2013 15:58:40 GMT
there was a chap over ts who used a auto box on a ztec just had 2 mod a flywheel to suit
RobinJI
Dec 15, 2013 16:47:18 GMT
Did Mazda MX5s come in auto?? that may fit?? Yep, and they're not that rare or expensive either.
kenb
Dec 15, 2013 21:33:53 GMT
Did Mazda MX5s come in auto?? that may fit?? Yep, and they're not that rare or expensive either. Only problem is, the Zetec isn't a Mazda engine and was the last of the line to retain the "traditional" Ford bell housing pattern. The Duratec (Not ST170) is Mazda based though.
RobinJI
Dec 15, 2013 21:45:21 GMT
I think the idea was more using the Mazda engine and box as an alternative to a zetec altogether. Well that's what I was meaning anyway, not sure about Ian.
Dec 16, 2013 14:56:19 GMT
Any C3 ford auto box will fit I've got 1970's vintage C3 with Mondeo Zetec Starter ring sping plate thinge, you will have to make a spacer about 5mm thick and a new bracket for the flywheel sensor and do something for the speed sensor, i'm using a modifired type 9 right angle converter for the speedo drive, oh and a spacer for the starter but the rest is easy. All left to do is setup something for the kickdown cable.
