got to face the fact that this may never get done due to work and loss of storage so here goes
got this of ebay a few month ago a mk2 escort estate reg mex ###p basicly a shell that needs welding to front screen scuttle and wing rails
front panel is new but needs refitting bit of work on door bottoms and needs a bit putting in on drivers inner cill its had new kick panels
needs o/s rear wheel arch n/s is new but needs finishing rear hatch is good but needs little work n/s rear lights have been modified to 4 single
light holders o/s needs doing and car has a sun roof fitted rear air vents have been filled in right what i have done
cleaned and fitted new rear springs rear axle half shafts and diff all with polly bushes so it rolls and stears currently drum brakes up front
parts that come with it
2x1300 x/flow engines
1 auto box with pedal box/shifter
Manuel box/pedal box
clean and painted front legs/ no disc or callipers
poly bushes for front end
and a prop shaft
grey carpet
all glass and rubbers
standard rear lights
and other small bits
set of deep dish mex steels with rally tyers
4 13inch road tyers
will try and get pics up later this was also on motornutz website under members projects and ebay
looking for what it ows me £1000e or swap for classic winter hack while my cortina is parked up for winter cheers allhttp://www.ebay.co.uk/itm/190864080227?ssP...984.m1555.l2649
and a prop shaft
grey carpet
4 13inch road tyers
