roadwarrior
Modified the mad max way
hi all pick up a supercharger a while back but haven trouble identifing it. can any one help have stripped it apart and can not find any part numbers of any form of identifictation.all can find is numbers on the NSK Japan bearings. it is a roots type blower. hope someone know want to get a manual an spare so can rebuild.
Ooo I recognise that!
It had a Nissan badge with it but I could never figure out exactly what it was off. Have a chat to Ratlook Reliant and CR500DOM, they seemed to know a bit more about it. From what I could make out it was mounted up on its side as standard but it looks like it would be ok to run it vertical as long as you had the right amount of oil in it.
Worth a chat to Nigel at Uk Blowers, helpful if a little expensive: 01564 703976 or email ukblowers@aol.com
B-8-D
down to one car!!
it looks J to me maybe a mr2 blower? ive got a 1460cc toyota blower but ive not seen a mr2 one (its little bruvver) apart from a quick glance... sorry I'm no more help.. si
Snoozin
Toyophile
Looks very much like a Toyota SC12.
Last Edit: Apr 2, 2007 21:46:21 GMT by Snoozin
it looks J to me maybe a mr2 blower? ive got a 1460cc toyota blower but ive not seen a mr2 one (its little bruvver) apart from a quick glance... sorry I'm no more help.. si This is the closest I could find but I couldn't find much info about blown MR2's. What I remember is it is designed to be run at 1.6:1 and no higher than 10,000rpm
roadwarrior
thanks guys. have already been to toyota had the go through all their manuals and computer systems, it was the us spec mr2s that had charger. looks very similar to it except for the end houseing covers. so still unshore really...
Mr K
i used to own that, it came from a chap who had it on an open manta A, which had been supercharged by some company (cant remember the name) when it was new, he then whacked it on some other manta with a different engine (sorry for the vagueness). it had a nissan sticker on it when i got it, but it fell off. it looks simular to the ones used on toyotas, but its not, although it may be the same make (i.e. the same bearings and oil maybe?) another port of call is the nissan super turbo, its not the same, but simular if i remember correctly. somewhere i have a video of it in action on the manta, ill let you know if i find it! had a quick search and all i came up with was this rather interesting looking electric supercharger. wonder if it works? if your going to all that trouble why not use a belt?
roadwarrior
thanks agian will keep up the search
roadwarrior
hi all been trawling the net it does very much look like a sc12 charger. cant find any nissans with scharger. any one know of any as a place to look?
Mr K
nissan micra super turbo........ its not identical but simular, i spent ages looking around for what it was off. it might be somthing J and obscure as it was bought new for this manta by that comapny i mentioned (that i cant remember the name off).
Rings some bells. Isn't there an SC10 on the Nissan micra march turbo and the SC12 was its bigger brother on the 4AGE or 4AGZE engine... I can't remember 100%
Mr K
somthing about a big toyota strait 6 rings a bell too.
Snoozin
Toyophile
There was also the Toyta SC14 which came on the 1G-GZE 2l straight 6.
Mr K
There was also the Toyta SC14 which came on the 1G-GZE 2l straight 6. thats the puppy, check taht out. ill find you the guy i got it froms email addy if you want.
roadwarrior
thanks guys will get on to it
