Okay... i'm finally just about getting round to refurbing my alloy wheels. I'm having the tyres removed tomorrow so I can get sanding, and then I'm going to paint them gloss black.
What grade wet and dry should I use to rub down the old silver paint?
Is there a special primer I need to prime alloys?
How much primer / paint am I likely to need for 5 wheels?
How vital is laquer?
Adam
half a can of each paint per wheel is about right
laquer isnt vital
SPLIT RIMS ARE FOR WINNERS
half a can of each paint per wheel is about right laquer isnt vital What size can is that? 500ml?
one of the big uns
dust on a bit of primer just to get it going. then after thats had 5 or ten minutes give it a half decent coat. another few minutes another good coat, then leave to dry. then wet and dry it with a high grit. then a good coat and leave to dry
then repeat that for the actual paint
then again for the laquer
peice of piz
just remember to prep it well otherwise it'll show
Is that just ordinary primer or is there some special primer needed?
nah just piz weak primer will do unless they're for a show car or something i always use cheapo primer and ive never had any problems
nah just piz weak primer will do unless they're for a show car or something I always use cheapo primer and ive never had any problems Okay They gonna need a lot of time to rub down! I'll be sick of BBSs by the end of it
bbs's ?
id get em blasted, cos its gonna do your nut in
bbs's ? id get em blasted, cos its gonna do your nut in I'd love to get them blasted, but I'm on a budget and I've heard sandblasting is too harsh for alloys.
