hak074
I'm going to stick a battery cut-off switch into my Escort track car. I'm just wondering if it is ok to do that on the negative side of the battery. Its the short cable in the photo below. Its just in a better position to reach it from the drivers seat while strapped in.
shin2chin
If its for track regs it needs to cut off the engine so would need to be an FIA cut off switch in the + side. If its just for security or to stop battery drain - side is fine.
v8ian
If you have the switch by the battery, and turn it off before you turn off the engine, you can toast you alternator as its not quick enough to sense the lack of load and blows the diodes, FIA type switches I believe have a small bypass within them to avoid this.
shin2chin
If you have the switch by the battery, and turn it off before you turn off the engine, you can toast you alternator as its not quick enough to sense the lack of load and blows the diodes, FIA type switches I believe have a small bypass within them to avoid this. Yep thats right
hak074
Thanks for the replies guys. Eventually I was going to hook it up to a pull cord outside the car, so I might have to go back and have a look at my switch, cause I don't think its an FIA one, it was good and cheap I should do it right the first time so I don't have to re-do the job later on.
Nov 13, 2013 13:10:05 GMT
Is it just me who finds it odd to see a battery laying flat on its side?
Is it just me who finds it odd to see a battery laying flat on its side? Yes, it's just you ...lol
RobinJI
Nov 15, 2013 10:13:21 GMT
It is pretty unusual to see them on their side, with most batteries it'd be a very bad idea, and a sure-fire way to get acid everywhere, however little race batteries like that are the gel type and can be used any way up. (They're also found in mobility scooters, if you don't want to pay race-car-parts tax)
Nov 15, 2013 10:37:44 GMT
