crahel
Dansktaff; sills have been replaced with 100mm x 100mm square tubing 1.6mm and the outer sill has also been replaced with the same gauge 1.6mm. I am going to add more strength, but I think the new sills are more than strong enough. ![](http://i1000.photobucket.com/albums/af128/crahel/27032012425_zpsb6ae2020.jpg) ![](http://i1000.photobucket.com/albums/af128/crahel/27032012421_zps8fe980a6.jpg) ![]() i1000.photobucket.com/albums/af128/crahel/20130910_053520_zpse1c1fd3a.jpg[/IMG][/URL] ![](http://i1000.photobucket.com/albums/af128/crahel/20131106_153510_zpse95cc0df.jpg) ![](http://i1000.photobucket.com/albums/af128/crahel/20131106_153542_zps8234e7a0.jpg) ![](http://i1000.photobucket.com/albums/af128/crahel/20131106_153605_zps1a676fe2.jpg) In the last two photos ill be adding a bit more strength. C
Last Edit: Apr 18, 2014 4:00:05 GMT by crahel
1973 Lancia Fulvia s2 coupe (sold) 1998 Audi a4 sedan (sold) 2000 Nissan maxima (sold) 2007 Audi convertible.
crahel
Dansktaff; sills have been replaced with 100mm x 100mm square tubing 1.6mm and the outer sill has also been replaced with the same gauge 1.6mm. I am going to add more strength, but I think the new sills are more than strong enough. C Hehe, you already knew it from the beginning ;-) It's kinda radical but I like the idea! It will look nice. Cheers!
crahel
crahel
Last night I had a go at the new pillars for the windscreen. Shaped rectangle tubing to the window profile and welded it in. Now I must just make up the other bits and the top of the windscreen surround.
Pic's soon.
C
crahel
Apr 25, 2014 11:24:13 GMT
crahel
Got all the other bits to finish the windscreen surrounds, will update soon,off to the herolds bay in George for a weeks holiday.
C
crahel
Apr 26, 2014 21:11:15 GMT
Reached herolds bay and on holiday. But cant wait to get back to the lancia. Got withdrawl's.
79cord
Well at least by building up the w/screen surround from scratch you might add some strength & can add a bit more to the mounting flange to bond the w/screen in for extra strength instead of old style seals. Did you extend them down to the hinge pillars thoroughly as a lot of people tend to grab them climbing out of convertibles, & even E30 BMW Cabrio seem to have a reputation for stress cracks at the bottom.
crahel
Yip i have extended them down and made extra suports to strenghten them up. Old passager side was held together with lead. So ive made a huge improvement over the old.
kev13s
Wow! I was talking to you a couple of weeks ago over on Lancisti, can't believe you went ahead and done it! Looks well keep up the good work.
crahel
Back from holiday hope to get cracking on the car soon.
link Found this and thought it might be useful. Different approach to yours, but interesting all the same
Last Edit: May 19, 2014 9:06:42 GMT by dansktaff: missed link off original post.
crahel
Thanks dansktaff, ive seen an exact same conversion here in cape town. Looks good, don't like the soft top when its down looks non factory.
I'm going a hardtop look to make it more like it was meant to that way from the factory.
I haven't been working on the lancia for a while need to get back on it now, I want it to be drivable by December.
Cheers Craig
Last Edit: May 20, 2014 8:20:18 GMT by crahel
crahel
Feb 11, 2015 10:44:01 GMT
Its been a while, I've done a bit of work on the lancia lately. Replaced suspension ball joints, repacked the leaf spring, cleaned and grease cv's , replaced cv boots, removed wheel bearings(cleaned and greased) and leaf spring buffer rubbers have been replaced. I also replaced all the engine and gearbox mounting rubbers, and fixed the subframe which had a bit of damage.
All I have to do now is replace leaking gearbox oil seals and test fire motor and see what needs doing to it.
I worked on the windscreen pillars and its coming along nicely.
I will post a few pics soon.
Craig
Feb 11, 2015 13:16:23 GMT
Hello Very interesting to see this thread and the amount of work you have been undertaking. Keep up the standard. Excellent.
1975 Lancia Fulvia Series 3
1960 Hillman Husky Series 2
1972 Hillman Imp Super
1984 Renault 4 F4 Van
2006 Hyundai Coupe Atlantic [daily drive]
crahel
![](http://i1000.photobucket.com/albums/af128/crahel/Mobile%20Uploads/20150216_212703_zpsqa6p8y7h.jpg)
Gearbox mount.
Last Edit: Feb 17, 2015 4:48:06 GMT by crahel
crahel
![](http://i1000.photobucket.com/albums/af128/crahel/Mobile%20Uploads/20150216_212712_zpseu5agj1c.jpg)
New top suspension ball joint, sourced from a lada 4x4
Last Edit: Feb 17, 2015 4:49:18 GMT by crahel
crahel
![](http://i1000.photobucket.com/albums/af128/crahel/Mobile%20Uploads/20150216_212723_zpsd2qez2h6.jpg)
Suspension spring buffers replaced. (remanufactured in pollyutherane)
Last Edit: Feb 17, 2015 4:51:07 GMT by crahel
crahel
![](http://i1000.photobucket.com/albums/af128/crahel/Mobile%20Uploads/20150216_212847_zpsxameqpfh.jpg)
Disassembled spring cleaned and replaced anti friction material with polyethelene sheet. Seems to be the same original material used.
Last Edit: Feb 17, 2015 4:53:00 GMT by crahel
