Hey all,
Breaking this:
But only because i am using the running gear as a donor. As such the following is NOT available:
Engine
Gearbox
Prop
Diff
Hubs
Driveshafts
Brakes
Steering shaft
Loom
And so far the following is sold:
roof
windbreaker
front grille
Exhaust (crumbled)
So the following is still available:
Wheels (wont suit my kit car)
doors - £20 each!!, collect only
wing mirrors
front headlights
rear lamps
bonnet (seems to be aluminium)
dashboard
centre console
seats
carpets
Fuel tank / pump
pass. airbag
seatbelts
front and rear bumper (scratches but solid)
....anything else you can think you might need...
Offers in the £20 region for everything above bar the wheels will most likely be accepted.
Breaking this:
Engine
Gearbox
Prop
Diff
Hubs
Driveshafts
Brakes
Steering shaft
Loom
roof
windbreaker
front grille
Exhaust (crumbled)
wing mirrors
front headlights
rear lamps
dashboard
centre console
seats
carpets
Fuel tank / pump
pass. airbag
seatbelts
