Weighing in scrap?BenzBoy
@benzboy
Club Retro Rides Member 7
Mar 29, 2007 10:37:13 GMT
I've got a load of cast alu engine bits to weigh in for scrap - what's the best way to do this? Do the bits have to be cleaned / totally stripped? Do they take stuff like complete gearboxes and stuff?
Mar 29, 2007 11:38:27 GMT
You are better off giving your local scrapper a call (You will have to take it to them) - failing that ask on a local building site who "looks after there waste metal" they will point you to the nearest traveller who will probs give you a good price. BE CAREFULL THOUGH.
Mar 29, 2007 11:41:15 GMT
Be wary about getting travellers come round to pick it up, if they see other tat knocking about it will almost certainly go missing shortly afterwards. Take it to them if you can.
Mar 29, 2007 11:42:11 GMT
Be wary about getting travellers come round to pick it up, if they see other tat knocking about it will almost certainly go missing shortly afterwards. Take it to them if you can. I second that. Pog had a couple of scrap radiators nicked the other week!
@benzboy
Mar 29, 2007 11:53:18 GMT
Thanks chaps. There are metal recycling places advertising in the Yellow Pages - I was gonna take it round there to get it weighed. Just testing the water first in case it's actually only worth about 27p and not worth bothering with. There's a fair old amount though. Don't think I like the idea of getting Diddies round my gaff
Mar 29, 2007 12:08:24 GMT
Thanks chaps. There are metal recycling places advertising in the Yellow Pages - I was gonna take it round there to get it weighed. Just testing the water first in case it's actually only worth about 27p and not worth bothering with. There's a fair old amount though. Don't think I like the idea of getting Diddies round my gaff Weighed some aluminium in a couple of weeks ago, Got 70p per kilo.
bstardchild
Club RR Member Number: 71
Weighing in scrap?bstardchild
@bstardchild
Club Retro Rides Member 71
Mar 29, 2007 12:15:57 GMT
Only advice I can give is make sure it's not mixed metal
Alu = £/kg
Steel = £0.00000000001/kg
If you have steel mixed with the ally they give you mixed rate which trust me is a lot closer to steel than ally
Got about 125 kgs to weigh in at the moment but it's 95% ally (5% steel ferules pipes/brackets) so untill it's all ally it's not gonna be weighed in
@benzboy
Mar 29, 2007 12:23:14 GMT
Only advice I can give is make sure it's not mixed metal Alu = £/kg Steel = £0.00000000001/kg If you have steel mixed with the ally they give you mixed rate which trust me is a lot closer to steel than ally Got about 125 kgs to weigh in at the moment but it's 95% ally (5% steel ferules pipes/brackets) so untill it's all ally it's not gonna be weighed in Ah. Most of it is stripped, but the cylinder heads still have the tappets in, as they seem to be torqued to about 592,000Nm. Balderdash. I could do with just getting rid to be honest, but if there's a bit of beer money to be made... ;D
Odin
Mar 29, 2007 13:26:14 GMT
We got £40/ton on 'light iron' the other week, and only about half of that was even metal - the rest was wood and stuff. ;D
street
6.2 ft/lbs of talk
Mar 29, 2007 13:45:59 GMT
Got to that place in Ilkeston, forget what it's called but it sounds a bit like a magicians name, begins with Z. I weighed in a load of old alloy wheels there, they don't mess you about and it's only up the road
@benzboy
Mar 29, 2007 13:47:25 GMT
Got to that place in Ilkeston, forget what it's called but it sounds a bit like a magicians name, begins with Z. I weighed in a load of old alloy wheels there, they don't mess you about and it's only up the road I know the place! We could go over there next week if you want?
street
6.2 ft/lbs of talk
Mar 29, 2007 14:00:16 GMT
Yeah sure, i'm fitting a new wheel bearing tomorow so should be back this weekend/early next week!
Mar 29, 2007 15:05:01 GMT
Any bits of steel you cant get out smash with a sledgehammer. Before you take it in phone up for the rate first though, it goes up and down alot! I weighed in 12 alloy wheels and got £1.80 each. I was expecting up to £10. You can make quite a bit of money weighing in non-ferrous scrap. Copper pipes, old copper boilers and scrap lead are a good money spinner. Save up bits and pieces you have lying about and when you have a pile wiegh it in
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
bstardchild
@bstardchild
Mar 29, 2007 15:30:01 GMT
Any bits of steel you cant get out smash with a sledgehammer. Before you take it in phone up for the rate first though, it goes up and down alot! I weighed in 12 alloy wheels and got £1.80 each. I was expecting up to £10. You can make quite a bit of money weighing in non-ferrous scrap. Copper pipes, old copper boilers and scrap lead are a good money spinner. Save up bits and pieces you have lying about and when you have a pile wiegh it in Good advice
slater
Club RR Member Number: 78
Weighing in scrap?slater
@slater
Club Retro Rides Member 78
Mar 29, 2007 17:25:21 GMT
Just don't leave it laying outside as someone will go weigh it in for you for free!
Mar 29, 2007 17:48:37 GMT
Place I go, I just got £80 for a 900kg car shell with glass and interior still in. Had to dispose of 3.5 Ton of 310 S24 stainless a few weeks ago from work £1300/ton
Mar 29, 2007 20:05:22 GMT
just as a guide, alloy wheels make more than any other alloy scrap. and it seriously pays to ring round if you can. places can vary wildy. not sure what shells are making but, alloy wheels last month I think were making £700 a tonne*, cats are making £36 each this week. copper was making £3000 a tonne last month. bmws were making £50 each ;D if you can smash the steel out it'll help loads in value. if you can't try getting it weighed as irony-ally, better price than regular mixed round these parts.
*price from EMR in cambridge, colchester was only paying £500 a tonne. told you it varies wildly.
Kyle67
Mar 29, 2007 20:19:16 GMT
I got £157 for weighing in my 2 Granada's today.
Mar 29, 2007 20:52:40 GMT
i got £40 for a fiesta the other day in scrap metal value when we drove it to the wieghing in yard ;D
Mar 31, 2007 10:35:51 GMT
Is there a minimum amount you have to take.I have some old doors,bonnets,boots,steel wheels,alloy wheels,and lots of bits and bobs off old cars that i have stripped.Can anyone recommend anywere in Southampton.
