Hello sadly selling my mk2 caddy van due to starting college and cannot afford to run car and my van =( THIS VAN IS FAR FROM PERFECT BUT WOULDNT TAKE MUCH TO TIDY UP SO A GREAT LITTLE PROJECT its a X reg 1.9sdi with 160,000 miles (reads 90 on clock) it is lowered professionally with coilovers,axel flip and shorter shocks also had a brand new exhaust 15months ago (but seems to be blowing abit) just done the rear brake lines and oil and filter change. the front tdi bumper is still red as i didnt get round to spraying it and is crudely fitted.It has had a spray job in white with ups brown roof (not the best spray job but looks tidy with a polish no orange peel shines up well) the roof needs touching up (see pics) and rust around the wheel arches (he just sprayed over rust!) the tracking is slightly out due to fitting new ball joint and track rod end the roof guttering is missing but i have them in back of van also there is a dent on rear (see pic) the roof lining is missing (also in back of van) due to replacing Ariel the back is ply boarded (not screwed in properly due to fitting plastic trim) the front headlight is loose (clip broken) THIS VAN IS FAR FROM PERFECT BUT RUNS SPOT ON PULLS THROUGH GEARS FINE =) never let me down a tank of an engine . TAX is out at end of month but will put 12month MOT on it! The inside is abit mucky but will clean up comes with CD player (part of dash is missing) its got pressed euro plates also i think i have covered everything THIS SOUNDS WORSE THAN IT IS WOULD MAKE A LOVELY VAN =)
750ono
750ono
