Mar 26, 2007 21:42:20 GMT
all of a sudden my indicators are not working not working through indicator stalk or the hazard light switch .
checked all 6 indicator bulbs ,all appear to be fine . i cant hear the relay clicking either ,swapped it with another relay off a renault 19 which has the same markings on it . still no joy. finally checking with a multimeter ,the relay gets a feed .
any ideas ??
Mar 26, 2007 21:44:59 GMT
Dirty contacts, or maybe a faulty stalk/switch.
Only a guess though , i hate electrics!
OAP drifta Volvo 340,Williams power 1960 Beetle twin 40's 1776cc
:)It could be a faulty hazard lamp switch. On nearly all cars the hazard lamps AND the indicators are wired in such a way that if the hazard light switch is faulty the normal indicators won't work.
Mar 27, 2007 20:05:02 GMT
:)It could be a faulty hazard lamp switch. On nearly all cars the hazard lamps AND the indicators are wired in such a way that if the hazard light switch is faulty the normal indicators won't work. makes sense i have given a direct live to the circuit today i.e : straight from the battery to one of the indicator light"s leccy connector. than pushed the hazard light switch ,the direction indicators on the instrument panel lit up ,but obviously not flashing !! done the same thing with the stalk and the direction lights again light up whichever direction i turn . now am i right thinking both stalk and hazard switch are fine ??
Mar 27, 2007 20:16:47 GMT
:)Certainly sounds like the stalk is OK.
Mar 27, 2007 20:20:23 GMT
I may be boloking here, but also check the relay earth connection. If the relay has no earth connection it won't work. If the earth connection is through the body, rust might have developed around the connection etc...
Mar 27, 2007 20:20:41 GMT
:)I would try very quickly switching on and off the hazard lights repeatedly. Sounds bodgy but often that switch isn't used much and the internal contacts become dodgy. [is that a rhyme? ]. Be quite brutal with it, hammer the switch on and off with your finger very quickly!
Mar 27, 2007 21:03:33 GMT
:)I would try very quickly switching on and off the hazard lights repeatedly. Sounds bodgy but often that switch isn't used much and the internal contacts become dodgy. [is that a rhyme? ]. Be quite brutal with it, hammer the switch on and off with your finger very quickly! this is the relay in question ,the black one on the left . i have even took the switch apart .all looks perfectly fine in there . also operated the thing a couple hundred times today
Mar 27, 2007 21:18:03 GMT
Been having similar problems with the horn, indicators and winscreen wash pump on my car. All but the horn sorted now... i sourced it was the cigar lighter that was causing the problem for the windscreen pump and the indicator spades just needed a good clean. Just need to sort the horn now.
Mar 27, 2007 21:53:12 GMT
Been having similar problems with the horn, indicators and winscreen wash pump on my car. All but the horn sorted now... I sourced it was the cigar lighter that was causing the problem for the windscreen pump and the indicator spades just needed a good clean. Just need to sort the horn now. what has cigar lighter got to do with them did you find out
