Mar 26, 2007 19:17:37 GMT
ive got to barcoat, undercoat then paint. but; at the top of the wall where it meets the roof theres a gap. this is about a foot above me (6ft) and an outstreched arm. the wall is about 10meters away from the car. so the question is, will i get paint on the car the other side of the wall? bear in mind its my dads pride and joy. he seems to think it'll be alright. ta.
Mar 26, 2007 19:33:20 GMT
you will have some form of ventilation, right? All the paint in air suspension should go in the direction of the air flow out of the "booth" and the paint will settle out as dusty overspray on everything in its path to that source of freedom.
I might feel moved to chuck a dust sheet over dad's pride & joy just to keep the dust off it.
paulw
Mar 26, 2007 19:39:14 GMT
is it two-pack or cellulose? because two pack cures chemically it tends to stick worse than cellulose which is just dust once it's travelled more than a couple of feet in the air. Both might get on the car, but the cellulose will just dust off...
Lotus Seven '58 Ford Special 64 Barracuda
Mar 26, 2007 21:02:19 GMT
ill open a door and it'll be celly.
Stiff
'kin 'ell
Mar 26, 2007 21:04:29 GMT
is it two-pack or cellulose? because two pack cures chemically it tends to stick worse than cellulose which is just dust once it's travelled more than a couple of feet in the air. Both might get on the car, but the cellulose will just dust off... Correct. I'd do what Alistairk said and cover dad's car with something. You'd be suprised at how far/where certain oversprays can reach!
