I've got a 2 litre blacktop engine mated to a 4 speed Lada gearbox for sale.
Originally intended for the gfs Riva estate, but that's sold now.
It's running a 1.6 flywheel and pressure plate, with a ford 4 speed clutch plate which matches the Lada gearbox splines.
Gearbox is scrap, just used as a mule to check for alignment.
Starter motor is attached and engages.
Mating is done. Have a couple of exhaust manifolds to choose from.
Original plan was to run it on ESC ignition and get a banger carb manifold.
Looking for around £100. Engine is in Penistone, s Yorkshire.
