Mar 24, 2007 11:34:09 GMT
Hi Folks
Have posted this on the AR forum but I know there is a lot of Mini love on here too - can anyone help?
Mini is really throwing a wobbly this week. The car is running pretty badly and feels very hesitant - power is notably lacking under full throttle. Ignition compotents are fairly new and only the coil is older than one year. Car was serviced 2k miles ago.
She was run out of fuel quite recently - I'm wondering if some gunk has been sucked out of the tank and is causing the hesitancy. Pretty sure that something is also wrong with the ignition system too though - there is an occasional misfire under part throttle and noticable on tickover and the hopelessness in the rain is well documented.
Added to this, she's now started to make a strange mosquito-like noise on tickover. Seems to be coming from the water pump. Only audible on tickover. Water pump is a new one fitted last summer.
slater
Club RR Member Number: 78
Mini woesslater
@slater
Club Retro Rides Member 78
Mar 24, 2007 11:41:27 GMT
I don't relly nkow what to suggest other than checking everything and re-servicing it.
Could well be a fueling problem causing it
Mar 24, 2007 12:54:44 GMT
Ta Slater - what happened to the old metro engine? Perhaps it just needs an upgrade. 998cc is sooo sluggish!
Mar 24, 2007 14:42:14 GMT
Theres a float bowl on the side of the carb its top is only held on by 3 screws take the top off and clean out with carb cleaner as it can fill with gunk if you have no in line filter
Reynolds501
Volvos, they're boxy, but good.
Mar 24, 2007 16:54:37 GMT
Dollywobbler, What engine and carb does your Mini have? As lordyoung suggests if it is a HS4 carb (float bowl on side), whip the top off the float chamber and check for 'matter' making a nuisance of it's self. If it's a HiF (float bowl underneath) you will need whip the carb off to have a look in and clean it out. Another problem could be induction leaks, try squirting a can of WD40 at the carb and manifold flanges and also both of the throttle spindle seals when the engine's ticking over, noting if the engine revs pick up when you do so. In worn SUs they can leak air in around the carb spindles due to spindle bore wear. Also, make sure the needle jet isn't badly worn, this is indicated by a pronounced ridge around the top of the needle (not the brass carb needle). There is also a small internal filter in HiF units, I think anway, so well worth checking to make sure it isn't all gummed up with curse word. Also, make sure the float height is bang on the factory tolerances, too low or too high can make a dramatic difference to how the car will perform. Another thing, remove the dashpot and make sure the piston and inside of the suction chamber are not covered in 'varnish', if they are, use a fine metal polish to remove it all and then thoroughly wash the polished components, oil with WD40 and reassemble, making sure the piston rises and falls easily, on refilling the dashpot damper with oil and refitting the damper cap, make sure again the action of the piston is smooth and that it doesn't stick. I'd definitely fit an inline filter, they're range from around £4 to £10 from most parts factors and only take a minute or two to fit. Another thing to check is the vacuum advance line, make sure it's not broken, both the rubber connectors at each end are intact and not split or perished. Also make sure the vacuum advance unit is working. To do this, remove the vacuum line from the carb end and suck on the pipe, you should only be be able to suck so much out and on suddenly releasing the vacuum you should hear the advance unit clunk back. If you can suck unlimited air through the pipe and you can't hear the unit moving, it's most likely a split diaphragm, you don't need to replace the whole dizzy though, just the vacuum unit on the side. Once you're happy with the fuel system, I'd re-check the timing, plug gaps etc. There are a few other things you could check, but my creaking old brain won't let me remember! I'll post back when it starts working again
Mar 24, 2007 17:03:02 GMT
Theres a float bowl on the side of the carb its top is only held on by 3 screws take the top off and clean out with carb cleaner as it can fill with gunk if you have no in line filter I though metros all had HiF carbs, not the sort with the external float chamber.
Mar 24, 2007 17:31:27 GMT
have you got the right oil in your dashpot ? straight engine oil is too thick, i found 50/50 mix with 3 in 1 was a good mix for it.
ImpManiac
Imps... Imps... Imps...
Mar 24, 2007 19:24:07 GMT
Have you checked the dizzy cap for carbon tracks under a bright light? Also, you could try running the engine up in the dark - the darker the better - with the bonnet open and the lights off. You might see millions of tiny little sparks under there. Minis and Metros are known for it! Dizzy cap or HT leads get my vote. If it ran dry, maybe some gunk is blocking the float valve(s?). HTH. "I'm"
1966 Singer Chamois sprint/hillclimb car in white over blue two tone 1975 Triumph Stag long term project (over 20 years so far) in colour TBA 2003 Vauxhall Vectra GSi 3.2 in black sapphire
Mar 24, 2007 20:05:18 GMT
Whoa! Thanks folks. Was going to whip the air filter off and have a nose around but was soooo bloomin' cold!! Hopefully tomorrow (longer evening too - woo-hoooo!). It appears to be a HS4 carb as I did spot the float bowl thingy - if that's the thing on the drivers side of the carb.
Dashpot is fine. Thought I'd replaced the dizzy cap. Gonna dash out now and check if there are any pretty underbonnet happenings...
Mar 24, 2007 20:48:53 GMT
Bit of a result. Sure enough, pretty sparks. The dizzy is covered by a crappy bit of plastic which is meant to be protecting it. Pulled it up over the HT leads and the car started more promptly and ran more sweetly. Pulled it back down over the dizzy again and while I couldn't see sparks, there was clearly an audible misfire.
So, we'll pull off all the HT leads tomorrow, get that crappy cover off and maybe even squirt Ignition Sealer everywhere once we've cleaned the dizzy cap also.
Thanks for the input guys! We'll see if it makes a difference on the road tomorrow.
