Sept 22, 2013 17:26:29 GMT
hi guys really odd question but my 1995 corsa has a slight hiccup, when at say 70/80 on the motroway in 5th sometimes the high beam light will flicker on and off on my dash panel and the high beams themselves obviously flicker, i really found this extremely odd, could it be a duff stalk?! anyone else expreienced and rectified this?!
seriously baffled! :/
Sept 22, 2013 17:43:18 GMT
Could be a duff stalk but it would happen at varying sppeds not just 70/80. Some Corsas suffer from a wire loom fault behind the dash display, corroded terminals or muti-plugs I believe and the speedos are electronic so that could be triggering the lights, so its worth checking that out. You would possibly get more info on a Corsa Owner forum.
RobinJI
Sept 22, 2013 17:53:44 GMT
Does the full-beam warning lamp ever come on very dimly when you've just got the dipped beams on? Before anything I'd be checking the lights earths and cleaning up any plugs, it could just be a vibration in a connection where something's finding a resonance at those speeds, and a connections vibrating off/on.
Sept 22, 2013 18:14:02 GMT
the full beam and all other lights worked / work fine it must just be the vibrations throughtout the car , i will try to find some time to clean the earths, just wanted a 2nd/3rd opinion from you guys really ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
sal
Mk2 Cavalier CD
Sept 23, 2013 8:43:39 GMT
I had same fault years ago on a calibra. Replacement stalk from scrappies sorted it out.
taurus
Sept 23, 2013 15:24:03 GMT
Yup - as above. I work on a shedload of Corsas and so far that problem has been the stalk every time. They're cheap so replace it with a new one.
You can try taking it to bits - but you'll soon wish you hadn't!
