here for sale is a l reg Vauxhall cavalier 4x4 turbo. it has 10mths mot 4 mths tax. the turbo is in need of a seal replacement as its smokey and the oil pressure and battery charge gauges need putting back in, but they come with the car. on the positive side it has had quite a lot of mods, the pistons and con rods are forged and it has a multi layer steel head gasket. and recently has had the head re built with new valve guides and new valve stem oil seals and re cut valve seats. the head is the coscast type. it also has 330cc injectors, enlarged top hat and 3inch intercooler pipework with a fmic behind the front bumper. the ecu has evo 5 superchips. the 4x4 transfer box is locked so is constant 4 wheel drive and the 6 speed gearbox is smooth with no crunching or whineing. the interior is in good condition with no drivers bolster wear and is the rare cloth not leather. call or text 07855659716 thanks.
If you check the website "ctor" you will see that there are only around 240 genuine cav turbos left
Car is located in Bridgwater, Somerset. PRICE DROP £2700
