I am going to try to keep this simple.
Saw a smoker cooker on a VW Caddy recently and thought the Redneck Express could do with one.
![](http://i294.photobucket.com/albums/mm90/niknakpix/Billybob115_zps4ebc3bec.jpg)
![](http://i294.photobucket.com/albums/mm90/niknakpix/Billybob116_zps0c7b0694.jpg)
My mate Woodsie who is in demolition, saved us a couple of knackered gas bottles from the steel skip.
The valves were already missing.
![](http://i294.photobucket.com/albums/mm90/niknakpix/Billybob118_zps1162333a.jpg)
As an added precaution I filled them with water before starting to cut them to prevent any ignition.
![](http://i294.photobucket.com/albums/mm90/niknakpix/Billybob119_zps7b0f22dd.jpg)
Then carried them to the garage, found some vintage heavy duty steel hinges, and used a flap wheel to grind back the paint to prep the area where the hinges were to be welded.
![](http://i294.photobucket.com/albums/mm90/niknakpix/P1030524_zps2ed6998e.jpg)
After which I used masking tape to lay a line for cutting the bottles.
![](http://i294.photobucket.com/albums/mm90/niknakpix/P1030525_zps11f65aad.jpg)
Did the preliminary cuts, allowing the water to drain out to cut level.
![](http://i294.photobucket.com/albums/mm90/niknakpix/P1030528_zps67a2a1be.jpg)
Used my trusty magnets my mate Luke gave me to hold the hinges in place and tacked the corners into position.
![](http://i294.photobucket.com/albums/mm90/niknakpix/P1030529_zps074291a5.jpg)
After which I welded the hinges down completely followed by laying the bottles down and cutting almost all the way around with a 2mm cutting disc.
![](http://i294.photobucket.com/albums/mm90/niknakpix/P1030530_zps13be0bfb.jpg)
Next up I need to go buy some clip latches or decide if I may want to use a pair of nuts above and below the cut, to create a lock to keep the lid closed once I have completed the interior and also the chimney that still needs making.
Part two to follow soon.
