Falix
Aug 23, 2013 15:26:22 GMT
I keep meaning to put this up here, this will be a brief summary as to where it is today... Firstly - This swap has been rolling around in my head for a while, originally it was going to be into a corrado but parts prices are silly and I couldn't find a clean one for the right money. The idea was to use a Mk4 Golf PD150 engine & 6spd gearbox, to create and awesome diesel GT car, to do long trips in style and comfort. Anyway, I ended up impulse purchasing this, straight away swapped my Nothelles onto it: 1.6TD Mk2, LHD, painted audi meteor grey. Then chucked a set of Porsche handles on it: Then spent a very cold January afternoon ripping this out of a MK4: PD150 engine, 6 speed gearbox, looms, ECU. It snowed not long after: Collected parts: Rear gearbox mount & front mount: I was lucky that I found suppliers for all 3 engine mounts(eventually), as I wanted it to be a quick bolt in, not be messing around fabricating stuff... Engine on its stand for rebuild: Why rebuild? Well one, I have no idea how many miles this thing has done, and two, PD diesel engines like eating camshafts and followers, like so: (one of my previous PD engines was MUCH worse than this) Note, injectors IN the head, PDs are a wierd mechanical/electrical hybrid engine, where the injectors are cam driven but electronically controlled. New things! Putting back together: Meanwhile a frined built my engine loom, plug and play into the MK2 fusebox, run the MK4 OEM ECU and OBD-II port Will contnue in post #2...
Last Edit: Aug 23, 2013 16:18:00 GMT by Falix
Volkswagens!
Falix
Aug 23, 2013 15:29:24 GMT
...Continued D-Day: Cut chunks out of an OEM rear mount (not smart, but did the job temporarily) Bought a man-clutch from AMERICA!!! rated to 500lb/ft Put the engine in: Didnt like the corrado crossmember so changed back to a mk2 one, fitted up the loom and vac lines: More fitting up: You can see here the intercooler pipes needed changing, it was designed for a MK2 G60, we flipped it upside down... A friend made me some aly hardpipes: At the smae time, I swapped a fresh set of VR6 coilovers on and a Rallye rack with PAS, and a few other bits, I forget, anyways! Rocker cover gasket fix #1: With my best mate's Rallye: Some engine bay shot: fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash4/1003286_676209422395731_1576235144_n.jpgChillin' Driveshafts were not available at all from VW's parts bin, so we took some MK4 hollow ones and worked some magic: Also got some bits machined up to remove some d-day bodges: Fitted run-out OEM Ultraviolet electric Recaros: had to use a MK4 fuel filter which didnt fit the MK2 bracket so it was cable tie time... Couple more general shots, fitting up the return fuel cooler as hot diesel and a plastic tank isnt a good combo! At GTI International: one more update coming...
Last Edit: Aug 23, 2013 15:54:03 GMT by Falix
Volkswagens!
shin2chin
Aug 23, 2013 15:34:49 GMT
I really like those wheels, what are they?
Falix
Aug 23, 2013 15:52:00 GMT
Wheels are Nothelle N Classics, VW fitment, 4x100 ET38, bought off Mystery Machine(Bruce)on here!
Volkswagens!
Top work. Must pull like a train.
Falix
Yeah, going for a hybrid turbo when the engine comes back out, good for 240/ish bhp and 400/ish lbft.
Volkswagens!
Aug 28, 2013 20:11:52 GMT
This is fantastic, my ideal daily! I had no idea the PD engine and 6 speed box could be fitted to the mk2. I bet it flies!
Aug 28, 2013 20:16:45 GMT
BRILLIANCE, how many MPG are you getting?
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Aug 28, 2013 22:49:58 GMT
you legend! , I'm running a mk4 escort with a tweaked td engine and building a 2.5 td e30 bm ,.
facebook: rodney dean / rd transport
Aug 28, 2013 23:16:38 GMT
Did you use a Passat B4 TDi pedalbox, or did you make up your own bits for the DBW & hydraulic clutch? If you can see past the turbos made of chocolate and the camshaft/injector problems, then ARL & ASZ are great PD lumps
sumpcracker
Yes, I’m still here.
Aug 28, 2013 23:35:01 GMT
Sure I have seen this before...
Did you sort your grille Alex?
Falix
Sept 14, 2013 9:23:25 GMT
Did you use a Passat B4 TDi pedalbox, or did you make up your own bits for the DBW & hydraulic clutch? If you can see past the turbos made of chocolate and the camshaft/injector problems, then ARL & ASZ are great PD lumps Using a LHD corrado hydro pedal box with dbw pedal grafted in. Thanks for the love guys! Its not boosting properly so need to get vag-com plugged in and do data logs. 6spd physically fits but driveshafts are custom.
Volkswagens!
Falix
Sept 14, 2013 9:26:54 GMT
BRILLIANCE, how many MPG are you getting? 400+ miles to a tank kicking its head in everywhere. Once mapped i should see more. Fuel gauge doesn't really work properly at the mo so not done brim to empty as yet.
Volkswagens!
Sept 14, 2013 16:20:21 GMT
This is an awesome car with a really good conversion!!
don't suppose youd consider selling it?
worth a try...
Scott.
Sept 15, 2013 4:14:30 GMT
hi mate can you let me know the companys that you got your engine mounts from please. as i wanna do something similar and its 3 custom engine mounts or grafting mk4 golf mounts into a mk3 chassis leg for me which i might do but just wanna find out how much the mounts would be and weigh up the 2 options.
awesome car btw love the swap i miss my mk2
matt
Falix
This is an awesome car with a really good conversion!! don't suppose youd consider selling it? worth a try... Scott. Everything has a price! Sorry for no updates gents, back on it again now!
Volkswagens!
What a car, PD engines are nothing but awsomne, nice to work on, great power and loads of MPG's. Don't suppose you've got a diagram of the loom your mate made? Good work ;-)
I'm just an average man with exceptional hair.
Falix
Jan 15, 2014 10:30:42 GMT
No loom diagram, he does it all from his head, no loom boards, no wiring diagrams! So I finally made space in my workshop for another big hit on it: My list: Front end off: Electric mirrors in
Last Edit: Jan 15, 2014 10:35:50 GMT by Falix: pics
Volkswagens!
hamps
www.medwayrscentre.co.uk
Jan 15, 2014 10:42:05 GMT
oooooh i love it
