I have to sell my car, I have been using it for work and it's just not economical enough and I can't afford to keep it spare while I build up the business. Car is in Essex, near J28 M25, a few weeks ago I drove it down to Tankfest at Bovington loaded up with camping gear with no issues at all, I would happily drive it anywhere in the country with no worries.
BAD STUFF
it has some damage on the rear quarter, this has been there since I got the car and there is no corrosion.
Advisory at last MOT was rear discs and pads a little thin, and they have, over the last week or so just started squeaking occasionally when in traffic so obviously need doing now.
I think the handbrake cable snapped, I haven't even got under there to look at it I have just been managing without it.
Exhaust is a bit noisy, it's solid and wont fall off but I bodged it for the last MOT, cat is on there but other than that its just 25mm pipe, sounded nice and throaty but it has a leak and you can hear that now as well.
One headlamp wiper does not work, rear wash has packed in, the pipe has come apart in the footwell. I fixed it once when I bought the car but obviously not well enough.
It leaks clutch fluid from the pipe under the remote reservoir, should be a relatively easy fix but I have just been topping it up once a week, however it now needs topping up everyday so it needs doing. Clutch continues to work no problem as the leak is in the top so it never really gets much air into the master cylinder.
It's had a double DIN stereo in it that isnt included in the sale so there will be a hole in the dash, it had the premium sound system in it before it packed up so it has tweeters in the dash and rear pillars and speakers in all the doors though.
It needs a service but still runs ok
GOOD STUFF
The interior is pretty mint, it has half leather without wrinkly door panels (although both front plastic door bins are broken) load area carpet is stained but not worn and it may clean up, car may smell of dog as it has been used to transport canines in cages in the back however I have curse word all sense of smell so couldn't tell you, no one has complained yet!
It has blue lights in the clocks and I had the dash out and re soldered all the joints on the back so all the warning lights and clocks work.
Car has a an MBC on it, plus boost gauge plus I opened up the cold air feed in the airbox.
I put a new clutch slave cylinder in when I bought it along with new seals into the master cylinder.
Working Nivomats on the back along with a towbar with fully working electrics
It's never let me down in two years of ownership but I have neglected it so it needs love, it's a strong car though and still drives nicely despite the high mileage. 270k +
Tax until end of September MOT until mid November, will be for sale for a couple of weeks until the insurance runs out as I have no off street parking now, its scrap after that but I can't break it so it will be gone.
Forgot to mention, I have the V5 in my name 2 spare car keys (all the locks work on one key) and one spare petrol cap key, no spare remote fob, the one I have works fine. The alarm works as it should, car comes with some old paperwork, owners book service book, toolkit, locking wheelnut key etc etc.
Boost is up from 3psi to 11psi, small turbo gives instance boost and she really flies, will spin a wheel with no trouble at all when it comes on boost can be fun :S in the wet. Not been rolling roaded but I suspect she runs 180 to 190 ish bhp, car has been fine like this for over a year and will suprise people as well as being a great motorway cruiser, if you tow anything heavy though best turn the boost down a bit which is easy and takes about 2 mins.
BAD STUFF
GOOD STUFF
