Hi, I bought some Granville underseal from the local motor factors and it seems pretty decent, I removed and treated any rust that was present then scrubbed and cleaned my arch before applying this spray on underseal. I managed to get right up the top of the arch.
Datasheet
Here are the before and after pictures
Now I am a bit sad and I really want an underside that is minty!
I am going to refurbish the rear beam and respray/powdercoat it.
Would you suggest using this product for the entire underside or is there better alternatives, also what would you recommend for inside of sills?
Obviously my main intention is to prevent rust.
Thanks in advance Alan
Datasheet
