Jul 30, 2013 16:58:25 GMT
Right, so I just bought a car and its got some 7J wheels on it which are fitted by some shonky generic spacers. Tried taking them off and the amount of clearance is tiiiny, so I'm looking to go to something properly sized. Steel or alloys. Tyres aren't a big deal as I've just had some new ones fitted to these so I'll be swapping them over.
Thanks!
Jul 30, 2013 18:09:40 GMT
What is it? As the offset does vary a little bit?
Also what are the 7x15's it has?
Jul 30, 2013 18:16:11 GMT
m1keh
Jul 30, 2013 18:34:08 GMT
I've got a set of alloys that I bought - were on an Audi 80 - RH Classics in 7x15, 4x108 ET37ish IIRC. I think the centre bore is 57.1 for an Audi, so might need a turn out if you're putting them on a french motor. They're round and straight but the lacquer on the dish is flaking badly.
Send me an email and I'll shoot you some pics. Based in Berkshire.
Last Edit: Jul 30, 2013 18:34:57 GMT by m1keh
Jul 30, 2013 18:52:03 GMT
What is it? As the offset does vary a little bit? Also what are the 7x15's it has? It's a Xsara 1.6, the problem is there's only about 3-4mm clearance to the inner arch which has me worried about it. The current wheels are some sort of rather '90s looking 5-spoke Ronals, don't know the model name as the only numbers I can remember off the inside were the size and offset (ET15). Tyres on 'em are 195/55/15s.
omega
Jul 30, 2013 19:21:01 GMT
ive got some 3o6 and 406 wheels iam in notts
Last Edit: Jul 30, 2013 19:21:24 GMT by omega
Jul 30, 2013 19:48:57 GMT
on the rear of a pug/citroen with a torsion bar rear end they are very close anyway, but due to them moving in a perfectly vertical arch wont rub even when that close.
however I would check that the beam is not knackered.
for a xsara you need ET 15 to 10 for a 7" rim, a standard 6" rim is ET19, so I think you will be just fine.
Davey
Resident Tyre Nerd.
Jul 31, 2013 18:15:58 GMT
I actually have some c2 15" steels with very near new michelin tyres £60 and there yours.
Jul 31, 2013 19:50:04 GMT
wrong offset davey, they'll be ET 27, he needs 19.
Jul 31, 2013 21:58:40 GMT
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
Jul 31, 2013 21:59:28 GMT
Open to sensible offers on either set.
Jul 31, 2013 22:58:07 GMT
I got a set of 406 alloys 40 pound in bedford
Thanks for the help & the offers, but I just got some from a breakers.
