now then my 44 idf's arent letting any fuel through, so i pulled the top off them and cleaned them out - then i cleaned out the brass bolt just near where the fuel line fixes, which had a bit of dirt in it, then i took the jets out and cleaned them through
but still no petrol
how far do i have to go to get fuel coming through ? do i have to strip them entirely ?
can someone give me a trouble shooting guide ?
oh yeah and its deffo the carbs as fuel comes out of the fuel lines if i up end them
SPLIT RIMS ARE FOR WINNERS
carb troubleBenzBoy
@benzboy
Club Retro Rides Member 7
My first thoughts would be to look at the float assembly. Is the fuel pump definitely pumping fuel? There could be fuel in the line from the pump but not getting moved anywhere.
My first thoughts would be to look at the float assembly. Is the fuel pump definitely pumping fuel? There could be fuel in the line from the pump but not getting moved anywhere. consider for a moment that I'm a complete idiot float assembly is the thing inside the carb which looks like 2 little rubber blocks ?
carb troubleBenzBoy
@benzboy
Hehe, OK ;D. Yes that sounds like the float. There should be some sort of needle valve near to where the thing pivots up and down. That might be blocked. I'm not familiar with these carbs so can't be any more specific I'm afraid. To test the fuel pump (assuming it's a mechanical one) you could get someone to crank the engine whilst you stand with the disconnected fuel pipe end in a clear bottle. If fuel comes out you know the pump is doing its job ;D.
Last Edit: Mar 9, 2007 20:12:26 GMT by BenzBoy
carb troubleBenzBoy
@benzboy
Just a thought, when you took the tops off the carbs, were the chambers full of fuel? If they were empty I'd suspect a knackered fuel pump.
Just a thought, when you took the tops off the carbs, were the chambers full of fuel? If they were empty I'd suspect a knackered fuel pump. yeah they were empty like cheers you god like genuise you ;D
carb troubleBenzBoy
@benzboy
Just a thought, when you took the tops off the carbs, were the chambers full of fuel? If they were empty I'd suspect a knackered fuel pump. yeah they were empty like cheers you god like genuise you ;D Well, even a stopped clock is right twice a day ;D. In that case I'd look at the fuel lines and filter for a blockage (nice and cheap to replace). If not then shine a 100W lamp in the fuel pumps face and interrogate it, Gestapo-stylee ;D Let us know how you get on
Last Edit: Mar 9, 2007 20:35:15 GMT by BenzBoy
well I'm on it tomorrow then as everyones away and I'm left to my own devices
