Having a bit of a clearout. I've got these roof panels left over after completing my garage extension. They are from a sectional garage and are all odd sizes. Ther are some holes and a few damaged corners from where I have been moving them. 2 are 5 1/2" pitch and measure 100cm wide x 137 high (the two panels on the right).
All the others are 3" pitch. The 4 on the left measure 2 at 102cm W x 170cm H, 102cm W x 160cm H, 73cm W x 193cm H.
These ones are also 3" pitch and measure 104cm W x 93cm H, 73cm W x 106cm H, 104cm W x 40cm H.
Here you can see the difference between the two pitches.
£30 for the lot. Collection only from Benfleet Essex or I can deliver if you're not too far.
Mountney steering wheel boss. I think a Mini fitment but I may be wrong. £10 plus £5 postage.
MK1 Golf, Jetta, Caddy Choke cable £5 plus £3 postage
Mk2 Golf, Jetta non electric window centre console £10 plus £7 postage
Mk1 Caddy rear load compensator spring £15 plus £3 postage
Mk2 Golf 5 door pockets with custom fit Pioneer speakers plus keep fit window winders, door latch surrounds, door pins and mirror gaitors. £15 plus £10 postage
Mk2 Golf 90 spec Gti door trims from a 5 door £10 plus £5 postage
Mk1 Golf, Jetta, Caddy 5 speed gearbox from a 1.6 Gti Golf. £30 collected or I can deliver locally.
Pair of electric cooling fans from a Mk2 Mondeo ST24. I was using them on my drift car so some of the mount brackets have been trimmed off. Good working order. £10 plus £10 postage
