hi there happy people, I'm going for big brakes for my ae92 rolla!
however i have everything baring disks at the moment, as the disk prices are holding me back, but through research and help of a local auto factors toyota Rav4 disks are all the same as what i need baring the height, which is something like 1mm more, which allows the disk to interfere with the caliper carrier, as no enough space.
so my thoughts are some kind of thin spacer located between the hub and disk to take up this slack?
its relatively simple being 4x100 and 54mm center bore and would only have to be 1 or 2mm thick...
does anyone know anywhere that does these or if its possible?
Will
Will
