Right then! Where to start, I have a Skoda Fabia 1.4 Mpi for sale (131,000 miles on the clock), please note it is a non runner and will need to be on a recovery truck or trailer (towing would be a bad idea!)
It has :
MOT until June 30th 2013
NO TAX (SORNED)
FULL V5
2 Keys
A little bit of service history over the past few years.
Now the "spares or repairs bit" it broke down a few weeks ago and has been diagnosed as a C.V/gearbox fault (I think they said a c.v joint but don't quote me on that!)
Before this it did run ok (started first time) but did have a vibration which may have been the problem above or may be something else.
At idle there was slight smell in the cabin oily/fuely but I put this down to a slightly lumpy idle, although this would be up to you to investigate further!
Sills......One sill seems fine, the other has been badly filled (about the size of a tennis ball and will need fixing before the MOT! Rust around the same arch (with one bit the size of a tennis ball also!) Missing a few pieces of trim!
Exhaust at the tail pipe right at the end has a hole the size of a 2p!
Brakes seem a bit low but tyres in a better condition, brand new spare in the boot!
Has Air con (but don't think it works) but bizarley NO central locking/alarm/ or electric windows! (and also NO stereo)
Other than that it is in ok to good condition, a few small scratches/dents, runs fair otherwise! Does still give decent MPG and has a trip computer, nice condition inside.
I have tried to be as honest as possible although I have not checked over the car fully (I.e on ramps etc) so couldn't give you a definate opinion hence sold as seen/spares or repairs! It doesn't run due to the fault listed above but is viewable and can be started! As you can see iv'e mostly put the bad things but I prefer to list things in a negative light so that it's not dissapointing!
Any questions or for pictures give me a pm, cheers!
It has :
NO TAX (SORNED)
FULL V5
2 Keys
