Sept 14, 2013 11:18:03 GMT
Always worth asking on here too. I am looking for one of these plates to replace the plate I have that has been fitted with two gauges. If you have one to sell, trade, donate etc, which would mean I do not have to weld up and smooth over the existing one (which I can do as well) please PM me more details. The two dials will be relocated below the dash onto a decent carrier plate.
Sept 16, 2013 9:39:29 GMT
Sept 16, 2013 9:39:41 GMT
extra one
Last Edit: Sept 16, 2013 9:41:19 GMT by gordini: deurie kak as usual
Oct 13, 2013 16:47:51 GMT
So, just to put things into perspective..... I got a cheap, damaged hard top, repaired the damage and attempted to respray it in a metalic gunmetal grey colour (In rattle can finish as the rust repair worked so well) So after repair, primer and prep, I broke out the rattle cans..... FAIL !! (due to stiped narrow fanning) Rubbed that back, bought proper spray paint, used my small ALDI compressor and gravity fed gun..... WIN !!! Then back to Rattle can clear lacquer after two days...... OOOPPSS FAIL !!! (Again, stripes) So one more trip to the paint suppliers and bought more of the grey, and a litre of clear lacquer (Total cost now nearing £100 where a body shop would have come in) A few days of rain and drop in temperature this week, followed by intermittently clearing skies on Saturday morning.... I wet sanded the roof back again early Saturday, first coat down by 10.00 and a second coat by 11.00 followed by two coats of clear by 16.00 and back on the car by 17.00 I will wait a few weeks for the paint to harden and cure, then hit it with some serious hand buffing to deepen the gloss. Nicola had been on Ebay again recently and added a dead Kitty sticker to make the car go faster.... Lastly, I guess I can add that today was Tom, Nicola's baby's 18th birthday. Typical teenager, he did not want to get up for breakfast, but eventually chose McDonalds. When we got back he went into his grotto and into hibernation for another 3 hours..... KIDS ?? !! At this point I now should be able to get back to the truck.
Oct 13, 2013 17:39:03 GMT
Been a while, but the MX5 kept me busy when I did have free time after work and with the nights drawing in and day starting later, it just seems there is less light to work by. Which brings me to this lot below..... About 7 months ago I got a PM via an American Van site offering me some 6 foot strip lights from a school, by a retired school teacher who is into cars, and campers. So with a £40 courier cost to deliver the 10 lights from the middle of nowhere in Wales, they were delivered in April while I was in Africa on the Bike tour of a lifetime with my brother. When I came back from Africa, life in general, a new contract job and an MX5/Miata all got in the way of fitting the lights to the garage, where I actually only have two 4 foot lights and a variety of odd lights plonked about the rafters. So now we have winter, early darkness coming in, and with the Mazda finished, I can get back onto the truck. Plans for the truck over winter includes preparing the bodywork for fresh paint, making up the load body floor with the oak strips I rescued and still have to clean up and prepare for fitting. So today I started by pushing out the truck which has been stood the last month or so, as I did not need to use it and measuring and planning where the lights will be going. I plan on fitting four strip lights per side of the garage, making for 8 of them on a 10X10 meter garage, should be reasonably light along with the white I painted the walls earlier this year. First job was to cut some sections of wood that will be screwed into the sides of the rafters so that I can fit the lights behind and under my numberplate collection without losing any of the brilliance. Typically though, the wind and pouring rain broke up my fun after cutting the wood to size, so I started up and reversed the truck. When I started the truck there was some smoke.... oooppss. I also noted that there was a small puddle of oil on the trucks dribble spot. In the past it used to drop a few drops of oil per week after a good run..... this was not good for me. So the plan is to have the engine, and mechanics seen to by a proper American V8 mechanic (cue cash register draining noises) after which I will start the body work. (Ohh, and no, I will not be attempting the engine work, I suspect valve stem seals, possibly rings and header gaskets) Anyone know a decent, reliable, affordable V8 mechanic ?? PM me please.
93fxdl
Enter your message here...
Before rushing off to a mechanic, try some simple DIY fixes. First give everything a really good clean then check all bits you can see, oil filter tight / not rusty, pressure sender tight / not leaking etc then check the breather system, gummed valves, kinked / blocked hoses etc, if nothing leaps out at you, liberally sprinkle cheap talcum over the engine until it is covered in a white dust coat, start engine and watch for a dark stain to appear, as the leak stains the talcum. Also have you changed the oil lately as some oils will run out of older engines. Ttfn Glenn
Nathan
Club RR Member Number: 1
Oct 14, 2013 10:38:36 GMT
What colour is the smoke, I would do the cheap things first before handing over a wad of cash mate. I nearly did exactly what you are saying, but mine turned out to be fully synth oil being stuck in the car....The more liquid oil was leaking past nearly every gasket and also giving me white smoke.
Oct 14, 2013 12:09:17 GMT
Thanks Glen and BGT
I will give these things a go.
I suspect breathers etc could be partly to blame as well as a 600 mile trip towing the GrizzPod etc.
Last Edit: Oct 14, 2013 12:10:22 GMT by grizz
Oct 20, 2013 20:59:53 GMT
Been trying to get this job done for some time. Lights in the garage for when I start doing the body prep on the truck over winter. Up to now I had two 4 foot strip lights, but early this year, Euan "Moosevan" sent me 10 used 6 footers from a school that he had renovated. So now I have been getting on with that. I have added some strips of wood to widen the rafters and wired them in today, thanks as so many times to Mickey from next door for giving an extra hand and keeping me company. Result down the one side, the two short lights will be removed and fitted elsewhere. I am also fitting four 6 footers down the other side.
Grizz I've missed you, and your threads! Thanks to modern technology I've just read the whole of this thread, whilst being paid;-) Some excellent ideas and some great free finds especially the instrument cluster. Let me know if you need some absorb pads for your oil leak I've some spare kicking about. Now I'm onto reading the mx5 thread!
Oct 23, 2013 15:32:40 GMT
Grizz I've missed you, and your threads! Thanks to modern technology I've just read the whole of this thread, whilst being paid;-) Some excellent ideas and some great free finds especially the instrument cluster. Let me know if you need some absorb pads for your oil leak I've some spare kicking about. Now I'm onto reading the mx5 thread! Hi mate, thanks for that. I think the pads are a great idea, but I will carry on with my perspex sheet and sawdust from the woodshed. MX5 thread is more of a PITA than this one at the moment.
Oct 23, 2013 15:35:50 GMT
Well, last night I wired up and finished the second row of strip lights, looks brilliant in there now. I decided after seeing the difference in whiteness to throw out all the yellowed diffusers, unless there is a really valid reason to keep them, I think distract from the brightness of the lights. Now I have decent lights in the garage, there is less excuses and reasons not to work on anything over winter.
93fxdl
Oct 23, 2013 17:59:16 GMT
When soaked in oil, sawdust can spontaneously ignite. Do you want a firebomb under your truck? Cat litter can be used, another option is cement powder, as used by race marshals. Ttfn Glenn
Oct 23, 2013 20:43:15 GMT
Sand is used on the road for big spills but absorb granules are best. Like cat litter. We use the best stuff at work. Let me know if your coming this way I'll find a bag of it for you!
Oct 24, 2013 21:23:23 GMT
Sand is used on the road for big spills but absorb granules are best. Like cat litter. We use the best stuff at work. Let me know if your coming this way I'll find a bag of it for you! Thanks mate, will do. In other news. Looking the opposite way at the "electrics work bench" some of my bits and a 1960 plate with a bit of wear, thanks Don.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
cool truck , I think it needs a big old turbo diesel with no silencers and fueling turnt up,.
facebook: rodney dean / rd transport
Oct 27, 2013 20:14:45 GMT
Been out all day in Canterbury with Nicola, doing a bit of romantic reconnecting, after I asked her out on a date this morning. (Nice to date your wife from time to time) We ate too much bad food, had a McDonalds coffee and late afternoon a light lunch of Baguette with Boiled egg, mayo and loads of smoked bacon. We also bought some bargains through the day and held hands while shopping...... Yup, it's nice. Mickey next door just came knocking on our front door, pretty intoxicated..... (though he would totally deny it, I still love him to bits) Just in from a job he did in London today flooring an upmarket office and reception area in high traffic flooring. He managed to convince the project lead that he needed some of the flooring for my truck, as an alternative to the oak strips I still need to create out of the white oak skirting boards he brought home from another office refurbishment job a while back. I was looking at this old oak flooring a while ago but decided it was way too pricey. Got to love a bit of free stuff. So tomorrow when he is back to normal, he will unload the van and bring it around. Nicola's black iPhone just added for perspective.
Last Edit: Oct 27, 2013 20:16:15 GMT by grizz
Not much to report but nice to report. Mate Martin and his wife Amanda are just back from the USA and he brought loads of spares back in his baggage. I popped over today after taking a motorbike up to Worcestershire at 05.45 and being back in Maidstone by 12.30 So once the dogs had settled we started to go through all his treasures, and they are impressive..... from a full new wiring loom to disc brake conversion and power steering, the man has it. I also got lucky, and a great surprise it was. I am now one of the Walmart Family.... with a cool T-curse word in size XXL An also added was a parking reserved sign for the garage ...... Thanks mate !! Looking forward to seeing Martin's truck develop over the next few years.
Nov 14, 2013 18:24:52 GMT
About 6 months ago I sent one of my number plate trading buddies, Herb, on Garagejournal.com a parcel with some random stuff including some number plates I thought he may like. After he got the parcel and messaged me it was obvious he did like the stuff I had sent. This week I got in from work and found a parcel from Kansas...... Opened it and was blown away by the contents. Herb had collected very specific things for me over the last six months. Firstly, a 1:24 model of my Chevy in red, as a recovery/wrecker with a Corvette behind it. Just this week I had forwarded an Ebay Germany link to Nicola of a 1:24 model of a C10 Chevy in the hope that the hint would get me one for Christmas. The other things in the parcel including a used US Army number plate...... perfect for me as I am trying to specialize in what I collect. Thanks a mil Herb !!!
Nov 17, 2013 21:39:45 GMT
Bought an older 210 liter compressor from a friend last week, collecting this week. Happy at £100 for it. Plan is to clean it and service it, then use it to paint the Chevy truck. Years ago I restored a 1963 VW Beetle from this..... In other news, I went over to help mate Martin to put up a car port frame yesterday, started at 0,5'C at 08.00 and turned into a good day. We ended up working till about 19.00 which was about 2 plus hours after dark and then I went back today to help him get the roof on as well. Bunch of pics of the process. Front corner post was actually correct. After dark we carried on with the neighbours spotlight Today we got half the roof on when rain stopped safe play. Of course the whole motivation for this roof build is so that Martin can work under some cover over winter prepping his truck. And that pretty much brought another weekend to an end.
