goldnrust
West Midlands
Minimalist
May 15, 2014 21:22:17 GMT
Yeah fixing one end of the car does tend to show up the flaws at the other, haha. Good motivation as you say.
Considering it's a full size 4 door saloon of it's day, it's looking pretty small in those pictures!
ulver
May 15, 2014 22:42:59 GMT
Looks fantastic.
'99 Alfa Romeo 156 2.5 V6
May 20, 2014 11:21:07 GMT
Hi
Ive just bought a 1977 nuova super 1300 as a little project and have been looking through your thread. I must say what a great job your doing!!!
Have you by any chance managed to find somewhere to get a manual in PDF format or any other information about this car?
The car needs quite a bit of work and I'm itching to get the thing on the road first just to see what it's all about!!!
May 20, 2014 13:57:35 GMT
Looking good sir, looking very good indeed!
***GARAGE CURRENTLY EMPTY***
Clement
ambitious but rubbish
May 20, 2014 16:02:16 GMT
Thanks megiulia! Indeed I have been directed to some shop manuals, on this website: www.duettoinfo.com/shop/shop.html. There isn't everything there, nothing is about the Nuova in particular but most of them still make sense when you have one. Please post some pictures or get a resto thread together! What colour is it? Frankly when I purchased mine it felt quite a bit boatlike, but now that I've started redoing some of the suspension I have a feeling it should be a lot sharper. Don't be too disappointed if yours somehow doesn't live up to the Alfa hype... I guess the somewhat complicated suspension means a lot of play appears when it's worn, the engine needs good and well-tuned carbs to sing properly, etc. I drove the car 600 miles without trouble last week, and today while driving to get a sandwich for lunch I managed to crash into the back of a colleague. I destroyed the front RH indicator unit, bent the metal quite a bit, and the front fascia popped out. I'm actually lucky that the fascia was let loose because of its rivets letting go and not the plastic shearing instead, and that I actually have already bought last week some used indicators units and rear lights... the one on the left of the car was already broken, and I could only find the four of them! It wasn't expensive though (€30) so all in all I'm not too worried. They are in the post as I write and should arrive tomorrow. No pictures, I'm afraid I don't feel like it!
May 20, 2014 22:43:28 GMT
Thanks for the link, to the manuals ! The car is a sort of purply blue colour, originally it was white but was imported from Sicily to play a background police car in the film inkheart, hence the respray! The paint finish is not good at all but there's more to worry about than a paint job for the next year or 2!! Picked it up Monday, I've removed bumpers and have just taken calipers off to give them an overhaul, (car wouldn't move at all) Once that's done I've got to get the lights wipers etc all working then stick it in for an mot probably to be told it needs a magnitude of welding etc! I just want to get it on the road before I plan the project! From reading your thread I reckon what we're both trying to achieve is not a million miles apart! Will post some pics when I figure out how to do it (new to the world of forums)
Clement
May 21, 2014 10:46:53 GMT
One piston of each of the front calipers woulnd't go back fully, I removed the old dried grease, filled the new dust covers with molybdene grease and it seems to be working quite well now. If your car is from Sicily it might be not too rusty, but frankly the paint is fragile and the steel corrodes quickly so it won't be long before it has small holes everywhere.
I'm currently thinking about rebuilding every sub-assembly (front suspension, rear suspension, engine, etc), repairing the rust I find, and when there's only bodywork/paint left to do, take it all out and put it on a rollover frame. This way I wouldn't have to fight all the seized nuts at once, I'd have a better idea how to put it all back together, and reassembly would be easier.
I really want to take it all back to bare metal, otherwise there's no point to paint it all shiny and have a rusty car again two years later.
Last Edit: May 21, 2014 10:48:01 GMT by Clement
Clement
May 27, 2014 20:01:28 GMT
The damage done : I'm lucky in that I didn't damage the grille any further, the indicators housing is destroyed though. I'm waiting for one, that's been in the post for a week... I absolutely hate the Poste, they're the worst (they already lost one of those cool Fondmetal wheels a few months ago, remember? I never got it back). Well, BlamBlamBlam pschhht pschhht pschhht This week-end I found that one of the carbs was dropping fuel into the cylinders, and into the oil. So two days ago I adjusted the floats (which I had never done, thinking that one less step is one less occasion to screw things up), freed the accelerator pump mechanism which was hindering the full travel of the butterfly valves back to rest, which could have caused that problem. I don't know if it did, but it didn't suffice. Yesterday I went to drain the oil and get the sump bottom off. Before that I filled both carbs, and the front one seems to be dropping fuel still, cyl n°1 & 2 are wet. The float chamber has leaked about 2mm while I worked (2 or 3hrs) and 15 or 20mm of fuel during the night. The fuel level seems to stay exactly at the level of one small hole, I have to know what it's for. The bottom end of the engine, seen from... the bottom. Found this The pig-tail shaped one is non-ferrous metal, the other one is ferrous... The first one could be alloy from when the block was first machined, but the second is a tad more intriguing. This evening I received a parcel from EB-spares: 4 drilled & grooved discs, miscellaneous small brake parts (pins etc), clutch assembly, braided clutch hose, and the notable absence of the front wheel bearings which I apparently forgot to order, although it was the main reason for the order. Yay. I wouldn't say mojo is low, but the morale certainly isn't too high. The Weber carbs are pretty complicated to sort out, the car doesn't want to look like I'm making it better, and the Maserati still needs a fair bit of work and I'm still waiting for its reg papers...
Clement
May 30, 2014 20:53:46 GMT
All cleaned up, cut up a new seal, it's all back together. The front carb is still dropping fuel but at such a low rate I found it best to ignore it for the moment and just drive the d*mned thing. I'll have to redo the carb settings completely as I've modified the floats' heights (both set to 8.5mm), and I can't really take the carbs off without losing their sync. Tomorrow I'm driving to the workshop where the Maserati is, I've quite a list of things to sort out/investigate, but I won't do the cambelt yet (not feeling prepared enough).The good thing is that since it's about 150km away the Giulia should be running nicely by the time I'm back!
goldnrust
West Midlands
Minimalist
May 30, 2014 21:34:45 GMT
Sorry to hear that you're having a bit of a rough time with the old girl recently. Keep at it though, it's all part of the roller coaster of emotions that come with owning a classic Italian car! I'm not up on webers, but when I was chasing issues with my Solex carbs, I found it useful to have both carbs side by side, so I could compare how the two differed? And doing it on the bench, with a small cup of fuel to fill them when necessary was much easier than trying to work on them and diagnose the issue while they were on the car. Go out and enjoy it tomorrow, don't worry about the cosmetics they will get sorted in time I'm sure
Clement
Thanks for the support! I did put the carb on the bench and filled it with fuel, that's when I saw that the accelerator jets were leaking a drop of fuel every 10-15s tops. That's not bothering me too much, but what's currently being a pain is that the car doesn't want to idle nicely: when I unplug the spark plugs from cyl 1 and 2, it doesn't change anything, and yet both exhaust pipes are hot. The plugs don't seem particularly wet, and I get sparks of current in my fingers when I touch the wires so they should get some as well. I'll try and pop the idling jets out to see if they're blocked, but I don't think I'll have time to work on the Maser today
goldnrust
West Midlands
Minimalist
It does sound carb related, as thats the only thing pairing cylinders 1&2. Have you checked the balance of the carbs? If they're out of balance and it'll essentially idle on the two cylinders which are being fed the most air and fuel.
Also, could be going up a blind alley here… but seeing as you said you'd looked at the float heights, they're not too high are they? On the Fulvia when I set the float heights too high it would start and run ok from cold but once warmed up it was just running too rich at idle, even with the idle mixture screw fully lean.
Carbs…. what a pain!
Clement
May 31, 2014 11:47:41 GMT
I got a bit bolder with the sync and managed to get it running. I cleaned the jets and changed the spark plugs, and it now runs but it's not all good yet... at least I'm almost at the workshop, I'll try to sort things out better tomorrow.
Clement
I had a blowing noise in the exhaust, that's the culprit found then. I'm back at my training course facility (still trying to find a suitable expression for this) in Dijon, so we have plenty of TIG and MAG welders lying around, not a problem. Speaking of welders, I think I'll try to start tackling the rust next week, starting with the doors and working my way randomly as usual. It might sound petty to seasoned car tinkerers but it's the first time I'll ever lay a hot metal glue stick thingy on one of my cars, I'm glad I made it look awful beforehand because it's a lot less of a drama this way. I had a look at the spark plugs, they certainly don't look too bad. Of course cyl. n°2 is very lean, but I've noticed that when idling, I can actually take its mixture screw out of the carb without any mixture coming out of it. That's it properly blocked then. Does anyone know about an OEM Alfa fully electronic dizzy that would fit the ol' twincam? Since they carried this engine on to the 00's with the TS, perhaps they have used one before switching to a Hall sensor and all that. I've grown this concern because of goldnrust, who stated that the vacuum advance on his Solex carbs wasn't the best, causing improvable drivability. There is no vacuum advance on the Webers at all! Hence my want for something unfortunately more evolved.
Maybe something from a later Spider, like the S3?
Click picture for more
goldnrust
West Midlands
Minimalist
Good luck with the welding mate That front carb doesn't sound healthy at all! Definitely wants a proper strip down. Have you got access to compressed air at this training place? Makes cleaning through the passages inside carbs quick and easy . My Lancia dizzy was mechanical advance only, like your Alfa. With electronic ignition timing there was a decent improvement in drivability, and I was able to dial in vacuum advance to suit the engine appropriately which helped even more. If you're pockets are deep enough, check out the 123ignition distributer. It looks like aboriginal distributer but inside it's got a small computer and so does electronic programable advance curves for both RPM and vacuum. Isn't it the 2L from the 75 which they swap into the 105 chassis cars all the time? Would someone like Alfaholics have the answers (hide your bank cards before going near the site though obviously…)?
Last Edit: Jun 2, 2014 20:46:22 GMT by goldnrust
I wouldn't say mojo is low, but the morale certainly isn't too high... When I get a low mojo moment I always (well, nearly always!) give the interior of whatever car is being a little git a complete clean-up! Give it a try if you've got the time, it can boost even the lowest of mojo's!!! Anyhow, you're still making progress with this wonderful car no matter how slow or difficult it may seem at times... It's getting better and that's a great thing to hold on to.
Clement
I dig your digging thanks a lot mate!!! Will see if I can find a scrap Alfetta somewhere that could be relieved of its distributor then. As for vacuum advance I would need to drill the carbs, which is said to be a bit tough (not much space to do so). Goldnrust> that Alfaholics thing really does hurt. So much good stuff, yet completely unaffordable! I've seen the 123ignition kit, it sounds really cool but is quite expensive still. At my parents' place there!s a compressor so I'll whip the carbs off again and clean them properly this time. It's quite hard to work on carbs when you have nowhere clean to dismantle them, but I should have thought about compressed air as a cleaning method... I'm too used to the ghetto method of WD40! Grifterkid> thanks mate, I've decided I had to keep going in order to see results, I don't really have a choice do I! The car could be a lot better but isn't too bad at the moment either, I just can't wait till I've got it properly sorted out... it will be a hoot. Two days ago I drove into town to have a drink with friends. Maybe it was because of the sunshine, but everyone seemed to love the car! Teenagers, old people, even a young British guy in a brand new BMW 3 series said 'nice car!' in traffic. It might sound vain and stupid but sometimes those little things do help me keeping going
"Two days ago I drove into town to have a drink with friends. Maybe it was because of the sunshine, but everyone seemed to love the car! Teenagers, old people, even a young British guy in a brand new BMW 3 series said 'nice car!' in traffic. It might sound vain and stupid but sometimes those little things do help me keeping going"
I love it when this happens. It's when you see someone break their neck whilst double taking that makes me chuckle.
