Dec 25, 2016 19:55:42 GMT
If you need a belt just measure the length and width I presume it's just a v belt and go to your local motor factors and they'll supply the right size for a couple of quid Thanks not even had a proper look at it, been trying to buy it for a long time, finally agreed to sell it to me, its tatty but the price was rings, should have a look in the next few weeks once I get on to of the other outstanding jobs! Why is an NVR better than a switch? Safety. If the power gets cut off to the drill,the 'switch' turns it self off ( basically speaking) so when the power returns the drill wont start spinning,with obvious safety consequences.
Thanks
It will come in handy even if you never use it
MR TIKI
TIKI,style from a different angle!
Dec 26, 2016 11:13:16 GMT
my belt reads A36/A950 FOBCO,I've not needed to replace one yet but I guess that's the size to look for.
Boldly driving faster than a tin worm can wiggle.
Thanks. I just need to get on top of all the other jobs then I can have a proper look at it
