Subaru Pick-up with STI running gear
All I know is the pics from here:
img78.photobucket.com/albums/v347/lewlew/?start=20
And some info from this thread:
forums.vwvortex.com/zerothread?id=1630706
But it looks seriously quick!!
Ran it on the weekend for the first time. 12.9 @ 108. Forgot to put the tailgate down which acts as a parachute ( don't run a torneo cover as I cut the clips off the bodywork.). Good for another 5 mph with it down . Also changing into 5th before the line which I don't need to do. So all in all it should be good for a flat to low 12. I'll be out again this weekend, first drive last weekend.
187kw atw which in hp talk is about 250 hp at the treads or about 330hp at the engine.
v7 jdm engine, variable cams,6 speed box with operating dccd, brembos all round, r180 rear dif, custom 3 inch tail shaft,motec m800 plug and play,3 inch exhaust, fmic,vf 37 twin scroll turbo with sti equal length race tuned exhaust manifold. Off the line through the first 3 gears it wants to boogie.
