May 20, 2013 21:56:21 GMT
Potentially a stupid question so bear with me.
What would stop you from machining a wheel with a centre bore of 57 to a centre bore of 65? Is it possible?
All the wheels I like are stolen from other makes but the centrebore is where I'm falling down...
May 20, 2013 22:07:23 GMT
if the bolt pattern and offset are correct then there's usually no problem at all doing this.
sparkyt
selling stuff
May 20, 2013 22:22:28 GMT
I know a place that does this very thing Plus redrills pcds etc all done on cnc mill / cutter .. We've had one set done are you local to Birmingham
MrSpeedy
East Midlands
www.vintagediesels.co.uk
May 20, 2013 23:14:07 GMT
I've also done it. No problem at all.
I've also done it. No problem at all. Can you also trim some meat off the rear faces of some wheels Speedy?
Koos
Generally wheel bolt tapers aren't machined leaving enough depth beneath to take anything much off the mounting face, especially on am OEM wheel
Last Edit: May 21, 2013 5:16:22 GMT by cobblers
I know a place that does this very thing Plus redrills pcds etc all done on cnc mill / cutter .. We've had one set done are you local to Birmingham Can you give me the details of the place you used in Brum for future reference please? Cheers Phil
Thanks for all the replies.
Sparkyt -I live in St Albans but I'm up that way a fair bit visiting family, can you PM me the details. Plus, the PCD re-drilling is floating my boat!
MrSpeedy - Where in the world are you?
Cheers.
sparkyt
selling stuff
May 23, 2013 21:53:48 GMT
0121 764 471 his name is H ..
MrSpeedy
East Midlands
May 24, 2013 11:11:41 GMT
MrSpeedy - Where in the world are you? I'm midlands based. Usually found around the Rugby/Daventry area
May 24, 2013 17:24:48 GMT
MrSpeedy - Where in the world are you? I'm midlands based. Usually found around the Rugby/Daventry area And you don't read through posts and reply
Koos
MrSpeedy
East Midlands
May 24, 2013 17:28:21 GMT
That's because I forget which threads I've posted in!
May 24, 2013 18:34:56 GMT
This one!!
And you should read all my posts coz they're all wonderfull anyway!! :-P
Last Edit: May 24, 2013 18:36:14 GMT by mdh
Koos
slot
Sorry don't mean to high jack this thread ! But does anyone know of a machine shop, in or around Manchester, that can do this ?
Cheers Dave
