1999 c70 2.3 t-5 spares or repair
mot ran out in april
tax is going back unless someone wants it for £50 on top of sale price,september 30th.
Metallic blue colour,not the prettiest but presentable,couple of rust spots and marks around the car.
The car has very little service history,I have used it as a stop gap and in the last couple of months have given it a full service all filters and spark plugs,new front discs and pads,top engine mount,strut top mount,auxiliary belt.
The engine is spot on and does not use oil or water,turbo does not smoke goes very well,manual box/clutch work as they should.
The interior is beige leather,non-heated manual seats with the in dash 3cd head unit which works as it should.
There is a problem with the brakes which may be master cylinder although the pedal does not hit the floor,a slight knock from the front suspension(last mot mentioned anti-roll bar bush)and a very slight noise from a wheel bearing.It may also need a couple of tyres.
this car has the me7 engine in it,so not so tuneable but all lights come on the dash and go out when started so no problems with ETM or anything.
car is near paisley,can be contacted on 07543764344
cheers Craig
cheers Craig
