60six
After quite a few belgian lagers I agreed to help rewire my mates new project - I didn't expect THIS Album imgur.com/a/heEgCWhat he forgot to tell me is that it hasn't got any wiring to start with. Anyone know of any resources that could help me get started? I have done work like this before but I always have had a semi working loom as a backbone so I am not too sure where to start - I know that how you would start a job like this can have a huge impact on how smoothly it goes later on.... I was going to back out but I could not refuse that face! (the project, not my mate)
Last Edit: May 19, 2013 8:33:19 GMT by 60six
stefan
If it isn't broken fix it till it is
Ha ha, no idea mate but it looks so sad you have got to help it
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
Alex-V
Haha sounds like fun mate!!
A mate of mine uses beal.co.uk as a resource for electrical bits, and generally a good little shop for workshop stuff.
Maybe search eBay for a wiring loom, find something cheap and local then go from there?
What Powertrain has it got??
Seth
Is that not VW type 2 based? Mechanically at least? Its not going to have anything much in it different to a type 2 so I think if it were me I'd start with a wiring diagram for one of them and work from there. Also: www.autoelectricsupplies.co.uk/www.autosparks.co.uk/
Last Edit: May 19, 2013 9:03:14 GMT by Seth
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
gn3dr
Never seen one before, looks like a giant Milk float. I love it. It needs a mouth though!
May 19, 2013 11:16:21 GMT
I did the very same with my mates ford pop (all be it I wasn't drunk lol) I planned to get a bit of block board and draw out what wiring I need and run the wires on it held on with nails then tape it together then fit it to the car then crimp the end with the appropriate crimps and then power it up it sounds easy in theory lol. You can get a wiring kit online that the hotrod guys use thats what I'm hoping to get to work with, when I remember where to get the kit I will post up a link
omega
May 19, 2013 11:28:42 GMT
I thought it was a tram!!
so what is it?
May 19, 2013 11:42:12 GMT
I thought it was a tram!! so what is it? Tempo Matador Caravan
Koos
chaseracer
If you have to ask why, you will never understand...
May 19, 2013 14:24:50 GMT
Is that not VW type 2 based? Mechanically at least? Really early Matadors had VW mechanicals, then the T2 put a stop to that. After this, Tempo worked more closely with Hanomag - both eventually being taken over by Mercedes. So it might be worth checking for similarities there.
60six
May 19, 2013 14:56:07 GMT
The drivetrain is a flat 4 1200 lump, with pre 66 5 stud wheels. Needs upgrading, and at least improvement of the cooling as I can't work out where it would get it's supply of cold air from - It's one of the only VW based vehicles that drives the front wheels - You essentially sit on top of the gearbox with the engine just behind you - It's gonna be damn noisy in there as only a thin plywood case separates you from the engine.
I am going to have to give it a mouth - Got some of that magnetic stuff that cab drivers use for their signs.
Thanks for the beal.co.uk site - never heard of them - going to build a list of what he needs. Wire. Lots and lots of wire, some plastic conduit / wrap / gas soldering iron / fusebox ... this list will run and run. My idea was to do the front first then the back and then join up to switches etc....
Quite looking forward to getting stuck in to be honest ....
Last Edit: May 19, 2013 14:59:03 GMT by 60six
60six
May 19, 2013 15:02:18 GMT
Haha sounds like fun mate!! A mate of mine uses beal.co.uk as a resource for electrical bits, and generally a good little shop for workshop stuff. Maybe search eBay for a wiring loom, find something cheap and local then go from there? What Powertrain has it got?? 1200 beetle lump - a little underpowered. Thanks for the beal.co.uk website, but I don't need DOGS, I need WIRE! - Furry friends are no good with soldering. beal.co.uk/album/spaniels/content/IMG_4429_large.html
Last Edit: May 19, 2013 15:03:11 GMT by 60six
May 19, 2013 15:29:07 GMT
Koos
Alex-V
May 19, 2013 15:34:46 GMT
Haha sounds like fun mate!! A mate of mine uses beal.co.uk as a resource for electrical bits, and generally a good little shop for workshop stuff. Maybe search eBay for a wiring loom, find something cheap and local then go from there? What Powertrain has it got?? 1200 beetle lump - a little underpowered. Thanks for the beal.co.uk website, but I don't need DOGS, I need WIRE! - Furry friends are no good with soldering. beal.co.uk/album/spaniels/content/IMG_4429_large.htmlHahahahah! Are they of no use to you? Try beal.org.uk (I will double check my suggestions next time) The real site has lots of bits that I always seem to struggle to find; grommets, plugs, terminals, trim clips etc They have box sets too which are quite handy to have
May 19, 2013 16:24:26 GMT
May 19, 2013 17:01:15 GMT
60six
May 20, 2013 14:31:27 GMT
Just purchased the popbrown loom - Thanks for the link
