This has now sold.
AEM Wideband Failsafe Gauge. The cool thing about this is it can display AFR and boost values simultaneously. The blurb from the offcial AEM website can describe it better than me:
It is in great condition. No scratches or marks on the gauge face and the harness has not been cut, includes 2 metres of silicone hose, USB cable, and 4 different face plates (black AFR, white AFR, black boost/vacuum, black vacuum). It was only fitted to my Volvo 940 for about 1000 miles (on unleaded) so the oxygen sensor is basically as new. Cost £230 from Summit in America, would like £160 posted.
Wideband Air/Fuel and Boost in One Gauge!
The Wideband FAILSAFE Gauge provides the ability to accurately tune AFR, while actively protecting your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy if it runs lean.
The Wideband FAILSAFE Gauge is a Universal Exhaust Gas Oxygen (UEGO—“you-way-go”) controller with an internal boost sensor, an internal data logger and a full color Organic Light Emitting Diode (OLED) display. It includes technology to activate a failsafe strategy in the event AFR falls outside of a user-defined operating window. If the AFR falls outside of the set operating window, the Wideband FAILSAFE Gauge triggers a user defined output function that can save an engine from catastrophic damage.
