benjy_b
Yorkshire and The Humber
I'm currently tinkering around on a friends bus (Dodge 50 series).
At the moment the offside main beam isn't illuminating. I've looked into it with a multimeter, it gets 12v at the plug on flash and switched main beam but no illumination of the bulb (H4).
The earth seems fine.
I'm at a dead end, I'm thinking a short in the wiring.
Any ideas?
Last Edit: May 8, 2013 12:03:06 GMT by benjy_b
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
Stupid question, but have you tried another bulb? I have had new bulbs give me issues before, generally when a policemant comes to check the car out as well!
benjy_b
Yeah, tried a number of bulbs :-(
As it's an H4 bulb and thus presumably combined main and dip, does the dipped beam work OK?
If it does, then that suggests that that the earth is fine as that's common to both main and dip on H4's, and thus logically the issue must lie with something on the high beam wiring/connector side.
1990 Peugeot 205 GTi 1.9 // 1991 Peugeot 205 GTi 1.9 16v // 1992 Peugeot 205 GTi 1.9 // 1999 Peugeot 306 Meridian HDi Estate
benjy_b
Yeah, sorry, I should have put that. Dipped beam works fine.
Rich
Club RR Member Number: 160
If a meter tests at 12v, it's still not a guaranty that there is enough amperage coming down the wiring to light a 55w bulb. I would expect with the symptoms to find a heavily corroded terminal, faulty burned relay or switch contacts or a wire where the insulator looks ok but the actual core is broken but carries enough amps to swing a meter to 12v but not light a filament. Start by making a new earth with new wire and terminals, if that fails, you'll need to start tracing wiring, or running in new loom sections. Take this as an opportunity to build a relayed headlight loom if the vehicle doesn't have relays as standard.
have you tried using a test lamp instead of a multimeter ? It could be down to cuurent flow as opposed to a voltage fault as Rich says
rld14
leef brings up a good point.
A bad connection can leak voltage through but not enough actual amperage to power anything. Older cars (Especially American) that use disc fuses on the back of the cigarette lighter sockets do this... the fuse will blow but on a Multimeter you'll get battery voltage or darn close at the socket but forget about lighting up a test light.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
sparkyt
selling stuff
Take it to Halfords bud ask them to fit you a new lamp
. Then sit back and enjoy the fun of watching the Muppets not being able to fix it ..
benjy_b
Rich - Thank you for the great reply. I didn't even think of relaying the headlights. 30 minutes work and we have fully working and considerably brighter headlights.
Thank you for the other replies... I used to work for Halfords, hence why I couldn't diagnose the fault ;-)
